The Midlife Crisis - My 833C Amp Build - Page 14 - diyAudio
Old 28th April 2013, 04:04 PM   #131
Magz is offline Magz  United States
OK, enough theorizing. In the next few days I'll hook up my 2500V PT to a variac and run the HT output to the board. Then I'll run the voltage up as high as I dare and check the drops across my "worst" bridge leg (luckily I noted which one that is). That ought to give us enough data to answer this question. Stay tuned; first I want to clean up the board a bit to ensure the voltages stay where they should (remove adjacent solder pads, round sharp points, maybe some high dielectric conformal coating).
PS: Yes I have a 50kV high voltage probe if I get too high up there ;-)
PPS: I'm having fun!
Old 28th April 2013, 04:39 PM   #132
nhuwar is offline nhuwar  United States
nhuwar's Avatar
Hey Magz,
If you don't mind me asking, how much is monolith charging for the output transformers?
Thanks,
Nick
Old 28th April 2013, 05:43 PM   #133
tomchr is offline tomchr  Canada
tomchr's Avatar
Originally Posted by Magz View Post
The 40 diodes I have all were within .007V for Vf - do they still need to be treated with the worst case scenario?
You're missing the point. If you read the SGS app note, you'll find the following in the first paragraph of the conclusion:
When using several fast rectifiers in series it is necessary to make sure that no diode will be subjected to continuous or transient voltages in excess of their ratings.
In most cases, this is achieved by using sharing networks across each diode.
It is important to optimize this circuit in order to reduce power consumption and to save space.
(Emphasis mine). Please read through that app note. It states specifically under which circumstances that you can eliminate the sharing networks. Do the math for your scenario rather than relying solely on experimentation and blog opinions.
You are trying to balance the REVERSE voltage, VR. **NOT** the FORWARD voltage, VF. It doesn't matter that the FORWARD voltage of the diodes in your batch are within a few mV of each other. It's the REVERSE voltage that causes the problem. If you exceed the REVERSE voltage across any of the diodes at any point in time, even briefly, it will break down catastrophically. When it does, it will take the remaining diodes with it. With the amounts of energy you are dealing with, this will cause the diodes to EXPLODE. Seriously.
If you surf the Ham Radio forums the consensus now seems to be that if the diodes are from the same batch, then resistors aren't needed; the caveat is that they are not talking specifically about SiC Schottky diodes, rather they focus on standard Si diodes.
No offense to any HAM out there. I used to be one myself, as a matter of fact. But how many HAMs, honestly, understand the semiconductor physics behind the reverse breakdown of a diode? Do they understand it better than the manufacturer does? I doubt it. Please read that app note.
If you're curious about the semiconductor physics, I suggest reading Ben Streetman, "Solid State Electronic Devices".
I cannot believe you are willing to risk a $10k amp build to save a few bucks on resistors. Never mind risking your life...
~Tom
Modulus-86: 40W/8Ω @ 0.000061% THD. HP-1: 3W/20Ω, 450mW/300Ω @ 0.000032% THD. DG300B and Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 28th April 2013, 05:58 PM   #134
Too much drama. Experimental evidence can't hurt, besides I'm enjoying myself, after all this is a hobby. Who knows, maybe it will help someone else down the road who has this same question come to a faster decision.
PS: Don't anyone else try this, EVER. It's too dangerous. There, that's my legal disclaimer.
Old 28th April 2013, 06:00 PM   #135
nhuwar's Avatar
If you read in current arrl amateur radio hand book they say this is not necessary with modern diodes.
I'm not saying don't put snubbers on them. Just food for though is all.
Nick
~Tom
Old 28th April 2013, 06:10 PM   #136
Originally Posted by nhuwar View Post
Hey Magz,
Thanks,
Nick
PM me.
Old 28th April 2013, 09:13 PM   #137
tomchr's Avatar
Good luck with your amp. Stay safe. Stay alive.
Old 28th April 2013, 09:41 PM   #138
nhuwar's Avatar
PM me.
Pm sent.
Old 28th April 2013, 10:16 PM   #139
Thank you.
Old 29th April 2013, 07:57 AM   #140
работник
Rod Coleman's Avatar
Maybe you can get away without, but balancing resistors can help reliability - and suitable parts can be procured to make it easy.
For example, I use the Welwyn MH37 series, which are rated for 3500V, and are almost as cheap as ordinary resistors:
MH37-470KJI - WELWYN - RESISTOR, H/V 0.5W 470K | Farnell United Kingdom
One more subtle reason for using them: Before the diodes break down destructively, you can sometimes get transient breakdown/leakage effects, that may not destroy the diode, but cause a lot of noise.
Especially if you choose to avoid balancing resistors, I would recommend a fuse in the PT secondary winding circuit - rated to be able to manage the HT voltage. A microwave cooker fuse is made for 5kV, and may be useful, depending on the VA rating of the PT:
Microwave Oven High Voltage Fuse 800mA 0.8A 5kV | eBay
A fuse in the secondary gives closer control, since the power-ON surge needs no accounting for.
mono block amps with 2 x 833C overkill ? even possible to DIY? Thesoundmen Tubes / Valves 25 9th June 2014 02:27 AM
Good Source for Nice Analog Panel Ammeters for 833C Build? Magz Tubes / Valves 12 7th March 2013 07:49 PM
Small and portable headphone amp Crisis firefart_1st Headphone Systems 15 26th May 2010 08:24 PM
Midrange + midlife crisis ronzeman Multi-Way 7 1st September 2008 02:39 PM
No More Sound Crisis john2890 Everything Else 1 23rd December 2005 06:50 AM
Copyright 1999-2017 diyAudio
