Found myself a Magnavox 9302-00
Old 6th April 2013, 06:59 AM   #81
lazzer408 is offline lazzer408  United States
lazzer408's Avatar
800ma? I hope that's not at 12v.
If the capacitance of the 6SN7 is an ignorable "issue" then I'll just go with those.
Last question if you don't mind. I'm still a novice so there are many things I'm learning but how do I determine (ballpark) drive requirement of a particular output tube?
Old 6th April 2013, 07:54 AM   #82
Eli Duttman is online now Eli Duttman  United States
No, that's at "6" V. The draw at "12" V. is 400 mA. The ECC99 pins out the same as the 12A_7 bunch and will operate on either "6" or "12" V. heater power.
The kind of "stones" the ECC99 has make sense if 300B DHTs or several multi-grid tubes in parallel are to be the "finals". The Miller capacitance is high, which is a "heavy lift". OTOH, the 6SN7 is more than capable enough to drive single multi-grid power O/P types set up in either ultralinear or full pentode mode. Even triode wired can be OK, with single tubes.
Eli D.
Old 6th April 2013, 08:04 AM   #83
lazzer408's Avatar
How about 2 pair 6L6 in PP pentode?
Found myself a Magnavox 9302-00Hide this!Advertise here!
9302 Maggie Rebuild lawdawg Tubes / Valves 50 24th January 2013 02:11 PM
For Sale Vintage Magnavox Speakers $75.00 or best offer Sal Brisindi Swap Meet 14 22nd July 2007 08:59 AM
For Sale: Ceramic 9 pin tube sockets $1.00 each 12 for $10.00 Sal Brisindi Swap Meet 0 26th June 2007 11:45 PM
18w8531g-00 vs. 18w8545-00 ermes Multi-Way 1 18th April 2004 06:05 AM
Copyright ©1999-2017 diyAudio
