12B4 vs. 12B4A
12B4 vs. 12B4A
Old 20th March 2013, 01:54 AM   #1
Richard Ellis is offline Richard Ellis  Argentina
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Default 12B4 vs. 12B4A
I may have a problem here, I have a quad of 12B4/As and I think pairing a 12B4 with a 12B4A will REALLY screw things up.
As I understand it the "A" version is a "slow start" version, the 'standard 12B4 is not. Paralleled on the outputs one will come up to temperature well before the other, drawing more current initially before the other....Bad idea? Smokin' bad idea?
__________________________________________________ _____Rick.........
Old 20th March 2013, 02:04 AM   #2
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
12B4 vs. 12B4A
if you have them connected like that , do not worry
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 20th March 2013, 02:52 AM   #3
Eli Duttman is offline Eli Duttman  United States
In 7 and 9 pin mini tubes, the "A" type suffix indicates controlled heater warmup time. That is of consequence ONLY when series heater strings are employed.
BTW, do you have heater current to spare? If so, get the nasty, non-linear, 12AU7 out and a linear 12BH7 in.
Eli D.
Old 20th March 2013, 03:39 AM   #4
Eli.........I have a 3A heater, the four 12B4s' will take 2.4A of that....I have a 'spare' TX split-bobbin at 12VRMS that I want to run thru a 317 to run the 12XXX. I have a AX and an AT .....I'll assume the AX runs "too hot"....I don't know about the AT...............don't have a BH. If I can readily get a BH........Is it a drop-in or do I have to re-bias??
__________________________________________________ ________Rick.......
Old 20th March 2013, 03:45 AM   #5
A 12BH7 will go in a 12AU7 "hole" without any wiring changes, IF sufficient extra heater current is available. The 12BH7 draws twice the heater current.
Eli D.
12B4 vs. 12B4AHide this!Advertise here!
12B4 Battery Bias from (Preamp: Foreplay or 5687 or 12B4 ) DougL Tubes / Valves 3 2nd August 2004 07:06 PM
