Simple hybrid amplifier
Old 19th March 2013, 08:20 PM   #1
FOXYE is offline FOXYE
Default Simple hybrid amplifier
Hello,
Is there any simple hybrid amplifier schematic/projects that recommended for construction?
Like the hybrid amplifiers from CROFT:
Old 19th March 2013, 08:25 PM   #2
Cassiel is offline Cassiel  Libya
Showing the chassis doesn't help much. The simplest one I've seen, don't know if it's good or bad.
Old 19th March 2013, 09:07 PM   #3
Do you have more information about the amp?
And how much power the amp can supply to 8 ohm?
Old 19th March 2013, 09:22 PM   #4
Tyimo is offline Tyimo  Hungary
Hi Cassiel!
Do you have more detail about this MJ hybrid amp??
Greets:
Tyimo
Old 19th March 2013, 10:08 PM   #5
kacernator is offline kacernator  Czech Republic
Default Simple Hybrid
Here you go...
Simple hybrid amplifier (35W/8Ohm)
Old 19th March 2013, 11:57 PM   #6
No, sorry, only the schematic. Got it from the Solid State forum, maybe if you ask there....
Old 20th March 2013, 01:40 AM   #7
Junm is offline Junm  Philippines
Junm's Avatar
Send a message via Yahoo to Junm
Good request foxye, i'm also interested in hybrids especially now that i have plenty of bjt's from ON Semi to use as well as power Mosfets to use as output buffer and looking for stable one.
also, maybe someone kind enough to share some schematics with Triode-Pentode tube as inputs. Like 6f5p or 6bm8, triode section as voltage amplifier and the pentode section as cathode follower...any schematics please?
Old 20th March 2013, 08:04 AM   #8
azazello is offline azazello  Bulgaria
azazello's Avatar
ELLA
It works! I tried with Hammond 125FSE.
Old 20th March 2013, 08:20 AM   #9
ErikdeBest is offline ErikdeBest  Switzerland
mostly thinkerer
last blog from Tubecad goes into hybids. I think that something like the first schematic, with OPT instead of the 2k5 resistor could work out quite nicely.
Supercharged Output Stages
but there are zillions of way to make simple hybrid amplifiers.
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
Old 20th March 2013, 09:11 AM   #10
jazbo8 is offline jazbo8
jazbo8's Avatar
Mr. Turner just presented a design recently, like everything that he does, it is very well documented, check it out here.
Jaz
Simple hybrid amplifierHide this!Advertise here!
Simple hybrid amplifier (35W/8Ohm) kacernator Tubes / Valves 23 21st June 2015 10:10 PM
Help Needed with simple hybrid microphone pre-amplifier Abdulla Solid State 8 23rd September 2012 07:29 PM
simple, hybrid Class D/G/H idea earthtonesaudio Class D 0 29th April 2009 06:48 PM
Simple Hybrid SE EL84 UL amp.. comments please. AudioGeek Tubes / Valves 2 10th September 2006 12:04 PM
simple hybrid idea nobody special Tubes / Valves 17 21st May 2003 06:30 PM
Copyright ©1999-2017 diyAudio
