Wiring a power transformer - Page 2 - diyAudio
Old 21st March 2013, 10:23 PM   #11
apologies for the confusion...but if you look at the picture you'l see 250V sec x 2 I think someone called it full wave TX...I'm not too clear on this
Old 21st March 2013, 10:30 PM   #12
DF96 is offline DF96  England
Two wires = one secondary
Old 21st March 2013, 10:40 PM   #13
That is clear now thanks.
I guess I got to find a different TX for my ECL82 project.
What about wiring the Fil.
A ecc83 takes 6.3V pins 4 & 5 and CT pin 9 and 6V6 takes also 6.3v pin 2 and CT to pin 7 (I believe) ... so how can I wire this 2 valves using 6.3V-CT-6.3V
Old 21st March 2013, 10:45 PM   #14
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Someone mention that I could probably use and I quote ''you can put them in parallel to give you 250VAC @ 160mA'.....how does that going.
Forget it.
That suggestion was based on your poor verbal description hinting at 2 250V secondaries , while you only have one.
EDIT:
Same confusing description as before.
You have *one* center tapped 6.3V secondary.
Old 21st March 2013, 10:46 PM   #15
For the ECL82 project I need 260V @ 100mA ...so I'm a bit short of current here.
Old 21st March 2013, 10:47 PM   #16
see post 8
Old 21st March 2013, 10:53 PM   #17
Hey thanks...
I definitely going for some lessons on power transformers ASAP.
Thanks all.
Power Transformer Wiring Question ? HP8903B Tubes / Valves 25 7th June 2013 11:21 PM
power transformer wiring help dscottguitars Instruments and Amps 3 2nd July 2012 03:36 PM
two transformer power supply wiring CharlieLaub Power Supplies 14 28th February 2012 03:45 AM
Wiring Power Transformer in Parallel kstylianos Tubes / Valves 5 7th June 2009 08:24 PM
Help with wiring a Hammond Power Transformer wonsup Tubes / Valves 3 7th January 2008 01:07 PM
Copyright 1999-2017 diyAudio
