D3a-300b amp help!
D3a-300b amp help!
Old 18th March 2013, 12:41 PM   #11
MartinR is offline MartinR  Germany
Hello Alberto,
you should also consider the usage of a anode stopper (22-47R) with such long leads to the anode resistor and coupling cap. Also the usage of ferrite beads on g1, g2, anode and cathode is highly recommeded with a tube like the D3a. To make things even better you can connect a 1nF ceramic cap from the each heater pin to the chassis.
Best regards,
Martin
Old 18th March 2013, 01:38 PM   #12
ErikdeBest is offline ErikdeBest  Switzerland
mostly thinkerer
D3a-300b amp help!
Hi Alberto!
great that you can move ahead now. I would really consider the recommendations given by the other members, like the precautions against oscillation and reducing the heater voltage on the D3a.
saludos Brasileños de Moçambique! Erik
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
Old 18th March 2013, 04:41 PM   #13
azazello is offline azazello  Bulgaria
azazello's Avatar
Ceramic resistors in cathode of 300B is not good idea. You can try to change to Mills resistors- 12 W and sound will be really great. Mills resistors page
Better You can use shunt el. caps Black Gate , Elna,
Old 19th March 2013, 11:22 AM   #14
Hello,
Of course, you shouldn´t use them if the heaters between 300B and D3a are shared. Only if the D3a has its own heater.
By the way, the best way to get a solid rock operating point of the D3a is to follow the datasheet by using a positive grid voltage (about 10V) and a higher value cathode resistor. But this requires a coupling cap between input and grid.
Best regards,
Martin
D3a-300b amp help!Hide this!Advertise here!
D3a triode as driver in Tubelab SE (300B/845)? cotdt Tubelab 0 3rd December 2012 06:33 PM
Question of D3a driving 300B Tubenstein Tubes / Valves 5 25th January 2012 05:30 AM
Looking for non-DRD 300B using D3a as driver jmillerdoc Tubes / Valves 39 14th January 2010 11:40 PM
Newbie building d3A DRD 300B stefanolo Tubes / Valves 8 3rd February 2007 03:51 PM
My experience building a DRD d3A/300B amp ligascon Tubes / Valves 50 1st November 2005 12:33 AM
