Choke? Where to begin?
Old 15th March 2013, 10:43 PM   #11
cogitech is offline cogitech  Canada
cogitech's Avatar
Schematic is only showing one channel... It is basically 12AX7 line stage, 12AU7 phase inverter, 2x EL34 power.
In its stock form:
As I said, it does not look exactly like this any more, as I have replaced all those cheap yellow caps, as per my earlier post, and the 4 pre-amp tubes are supplied by a separate (external) transformer.
Old 15th March 2013, 10:43 PM   #12
rfengineer2013 is offline rfengineer2013
rfengineer2013's Avatar
Vcelkamaja has a hum thread going on his SE kit that has a very similar front-end circuit.
The primary source of hum in his case was the filament AC coupling to the cathode in the upper 12AX7 input tube.
The voltage on the cathode in the top-section of V1 is about half-way between the top plate voltage and ground. In the other amplifier, the cathode was at about 155VDC and the heater was referenced to ground. Hum from the heater was coupling into the top cathode and was being amplified.
The primary solution in that case was to bias the heater up (I think he biased it up to 30V or so) and the majority of the hum was gone.
You might check out that thread - the heater bias circuit is described here: Hum in tube amp.
Your amplifier is a bit different, it has a rectifier on the 6.3VAC and a 10,000uF cap - but no series filtering element, just the cap. It's quite likely that you are still getting some ripple from that rectifier/cap circuit, it would be 100 or 120Hz depending on your mains frequency.
The 12AX7 in that configuration has lots of gain - a little ripple can cause a lot of hum.
The filament supply looks like it floats (i.e. - not connected to system ground), so it's still possible to bias the filaments up closer to the cathode in your amplifier.
And I agree with the other posters - just putting a choke in the amplifier is probably not going to solve your hum troubles.
Check out the other hum thread - you might get a better idea of what is going on and decide what your next step might be.
Good luck!
-- Just an average Man of Bronze --
Old 15th March 2013, 10:53 PM   #13
cogitech's Avatar
Note, due to the size of the replacement coupling caps and PI grid return caps, I had to get pretty creative with the connections.
Perhaps I shall take a photo of exactly what I have done and post it...
Don't get me wrong, the amp doesn't sound bad or anything. It's just that last night during a quiet passage I heard the variable "sizzling" and I'd really rather have it gone.
Old 15th March 2013, 11:00 PM   #14
cogitech's Avatar
Good luck!
Thank you (to all, really)!
I am really struggling to grasp a lot of what you are all saying.
My plan is to live with it for the time being, perhaps reflow some of my cap solder connections... Also, since you mention the 12AX7 having high gain in this circuit, perhaps I will stick my set of 12AT7s in there and see if I notice any change with the lower gain factor (?)
I need to learn several orders of magnitude more than I know now about all that has been explained above before I can ever hope to start tweaking the circuit.
By the way, the power transformer in this amp runs very hot. Even after adding a big heat sink, it is hovering around 150 F.
Old 15th March 2013, 11:08 PM   #15
I was poking around and found another thread showing your Orange Drop upgrade. Dang, you're right - those ARE big.
Anyway, I wanted to ask is this a "hum" problem or a "HUM" problem. The issue on the Hum thread was bad - it was a bonafide HUM problem that was the result of a poor kit design (also Chinese, BTW).
It involved much more than just adding a choke - in fact, a choke was tried early-on without success.
It required relatively major circuit changes to bring off. But in that case, it was worth it.
So, the question here is how much do you want to dig into this thing? If it's a HUM problem, it's likely the folks here can help you through it - but since you purchased this as a manufactured amplifier, I would think either there is a serious design issue with the amp -or- you got a lemon.
Hard to tell, but in either case the warranty (whatever it was) is probably void now. And I've heard returns to China are impossibly expensive anyway...
Where is this headed... Well, just to reinforce that upgrading and modifying commercial amplifiers can be a rewarding and educational experience. It's what we all enjoy doing, the building and testing and hair-tearing-out problems that come up.
But it's not quick nor easy in most cases, especially chasing down noise problems. And while the hood is up and the engine is all over the garage floor, the amp won't be playing music either (mixing metaphors and all that).
Up to you, but just fair warning that this can be a very addictive pastime and it will require a lot of perseverence to solve.
OK, back to regular programming...
(I was off writing this when your comment posted above. Good luck with the amp!)
Old 15th March 2013, 11:10 PM   #16
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
I use JAN GE 5751's in my Jolida. Circuit is very similar to your amp, basically the same SRPP front end.
Underspec'd for the current demands, as I'm sure has been mentioned already. The reality is it's a cheap amp, so shortcuts are going to be implemented somewhere.
jeff
Old 15th March 2013, 11:40 PM   #17
cogitech's Avatar
Just a hum (not HUM) problem. So not really a problem.
It was the variable "sizzle" last night that bugged me.
Home from work now. Wife has had it on all day. I cannot hear any sizzle now.
Perhaps the new Russian PIOs just had to settle in...?
I will listen intently overthe next few days to see if it returns. Fingers crossed.
Old 15th March 2013, 11:52 PM   #18
cogitech's Avatar
Just had another close listen. Intermittent sizzles or buzzes, but very infrequent (many seconds between very short zzzts), and seemingly random. I am thinking maybe RF from wireless network chatter...
Oh, and if I pause the source and wrap the volume pot to max, everything but the low-level hum disappears, and the low-level hum never increases in volume.
Will continue to monitor, but at this point my intuition is telling me that my sizzle issue is RF, exacerbated by the "antenae" on my huge caps.
Old 16th March 2013, 12:17 AM   #19
jjman is offline jjman  United States
If the amp was single ended I would say a choke would help. I tried going chokeless on my SE build but had to add one to eliminate hum. But you have a push-pull amp that cancels the power supply (and heater) output stage hum like a hum-bucking guitar pickup does. And it looks to me that there is adequate filtering to avoid PS hum in the PI and gain stage. I suspect a different problem/solution.
Old 16th March 2013, 12:48 AM   #20
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
I want to add a choke to my Shuguang I-25 (EL34 P-P) tube amp.
Been trying to do some research but feeling less confident the more I read.
Where do I start? What specifications of my amp do I need to know in order to choose a choke with appropriate specifications? What are the critical specifications of a choke that make it suitable for one amp and not another?
Any help at all getting me pointed in the right direction would be greatly appreciated!
a very good place to start... audiofilterchokes
and an electronic version...http://aquinaudio.webspace.virginmed...act_choke.html
and here...Gyrators
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Choke? Where to begin?Hide this!Advertise here!
Hi there, Where to begin? iamthefly Introductions 4 9th January 2013 06:35 PM
26H choke good enough for a grid or anode choke? speakerfritz Tubes / Valves 7 2nd December 2011 06:05 PM
Where to begin here ? Bluto PC Based 9 25th March 2011 05:17 AM
I want to begin but I don't know how!!! nicxxx82 Tubes / Valves 10 31st January 2008 05:18 PM
Where to begin? subcoolman Analogue Source 2 20th June 2005 06:30 AM
Copyright ©1999-2017 diyAudio
