Negative feedback to differential pair driver
Old 12th March 2013, 12:27 AM   #1
funk1980 is offline funk1980  Netherlands
funk1980's Avatar
Default Negative feedback to differential pair driver
Just wondering if anyone has used negative feedback to the differential pair used as CC drivers for the power tubes. I don't mean the phase inverter configuration, but the long tailed pair with two in- and two outputs.
Old 12th March 2013, 05:37 AM   #2
Jehan is offline Jehan  Indonesia
Jehan's Avatar
Could you upload the schematic which shows us what you've said? Nfb could make the amp design complicated with phase relationship of each input signal, if wrong phase feeded to the output, positive feedback is what you'll get.
Old 12th March 2013, 10:28 AM   #3
DF96 is offline DF96  England
Doing this at the driver stage could cause problems with common-mode distortion, unless you arranged negative feedback to both sides. CM distortion is less of a problem when NFB is applied at the input stage, as signal levels are much lower. Applying NFB to both sides carries the risk of extra phase shift, as you might no longer have a minimum phase system.
Old 12th March 2013, 08:41 PM   #4
Miles Prower is offline Miles Prower  United States
Miles Prower's Avatar
It's done frequently in the Circlotron OTL topology. No different, really, than how it's done with SS op-amps. The main thing to watch out for is that you buffer inputs that could be connected to different source impedances, as these add to the Rs resistor(s) and can unbalance/change the level of NFB you've designed for. It's not a prob with SS op-amps since these already use buffered output stages that have very low impedances.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 12th March 2013, 10:22 PM   #5
funk1980's Avatar
Thanks for all the info! I'll look into the Circlotron topology. I understand the necessity for balanced (buffered) sources, but for some reason, the workings of global NFB to the LTP elude me...
To make sure we're all talking about the same thing, I sketched up a schematic of what's in my head, as Jehan suggested. Is it still viable??
Old 12th March 2013, 10:45 PM   #6
No. Something like that is sometimes used in guitar amps, but there the aim is not fidelity but controlled distortion. The problem is that the feedback is applied in common-mode to a differential-mode stage. You should instead put the feedback on the second LTP grid. Then to avoid common-mode distortion use a CCS tail.
Old 13th March 2013, 01:11 AM   #7
Jehan's Avatar
I suggest to separate the driver cathodes by removing its tail, then put a remote sensing negative feedback from output transformer's secondary legs to driver cathodes. I think it would sounds fabolous.
Old 13th March 2013, 02:42 PM   #8
DavesNotHere is offline DavesNotHere  United States
try r5 and r10 being doubles as each triode have its own r5&r10.
then tie a 100k pot between where the nf was one on pin1 and one on pin3 of pot. tie pin 2 of pot (wiper) to the negative FB network.
adjust for gain linearity.
Old 13th March 2013, 03:02 PM   #9
Sorry, you lost me - could you explain your proposal in more detail?
Old 14th March 2013, 06:36 AM   #10
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
I did that in Pyramid amps, from anodes of output Gu-50 tubes, to anodes of LTP driver (R23, R28).
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Negative feedback to differential pair driverHide this!Advertise here!
How the negative feedback really works and an alternative feedback question Amit_112dB Solid State 37 21st April 2014 03:16 PM
negative feedback dscottguitars Instruments and Amps 7 13th September 2011 04:43 PM
Get away from negative feedback ? N-Well Pass Labs 3 1st March 2006 10:17 PM
Negative feedback? Solid Snake Solid State 33 14th March 2003 01:29 PM
