Bench Power Supply: What to look for ? Which one to get ?
Old 11th March 2013, 07:47 AM   #1
HP8903B is offline HP8903B
Default Bench Power Supply: What to look for ? Which one to get ?
Old 11th March 2013, 08:18 AM   #2
aardvarkash10 is offline aardvarkash10  New Zealand
aardvarkash10's Avatar
an old BIG tube oscilloscope. Donor parts for Africa includng a huge FO power transformer with about a gazillion tappings. Then take a quick search in this and the tools forums - the issue has come up before a number of times
Or, trawl the surplus gear places you guys in the 48 are so lucky to have on your back doorstep...
"It may not be easy for some to not hear differences, even if they are not there." - Vacuphile,
Old 11th March 2013, 12:23 PM   #3
artosalo is offline artosalo  Finland
artosalo's Avatar
I have a couple of these.
Heathkit IP-17 HV Power Supply
I found one older version available at Ebay now:
Heathkit IP 32 Regulated Power Supply | eBay
One possibility is to build your own.
With power NFET's it can be guite compact.
Old 11th March 2013, 02:53 PM   #4
boywonder is offline boywonder  United States
boywonder's Avatar
Originally Posted by manp111 View Post
As for requirement, I need two plate voltages (one for output tube and one for driver tube), 2 or 3 low voltage sources for the heaters.
If you want to play with fixed bias, you'll need a -ve supply also.
I made my own basic setup out of leftover/scrap parts.
HV is a variac connected to an old 360-0-360 tube TV transformer through a CLC with 500V rated caps. IIRC it's good for around 150ma and around 450V.
-ve bias is a small transformer (around 44V I think) with a CRC filter and a simple pot to give up to about -60VDC bias.
The two square illuminated buttons turn on the HV or bias supplies.
A filament transformer that is 12.6V-0-12.6V with all 3 taps on the front panel to provide either 6.3 or 12.6VDC.
The variac also controls the mains VAC on the receptacle for powering up stuff slowly. That feature is used the most by far........
Low-Tech, but works fine for my needs.
EDIT: Here is a fancier one by Pete Millett.....tube regulated
http://www.pmillett.com/HV_bench_supply.htm
Old 11th March 2013, 03:46 PM   #5
ErikdeBest is offline ErikdeBest  Switzerland
Agree with aardvarkash10 on the BIG old oscilloscope transformer. I have one from a 545 Tektronix, and it has a lot of relatively low voltage (2x 115V, 138V, some more) secondaries and about 5 or 6 6,3V windings with lots of A. I connected the HV secondaries (noticing phase) to a Euro barrier strip, allowing for series connection.
To use these I made 4 individual power supplies. Each power supply consists of a bridge rectifier and two stacked elco's (with bleeding R), allowing it to operate both as 'bridge' as 'voltage doubler'. Each elco is 250V, so I aim for a max of 450V DC. I use a LR8N3 together with a big 300k wirewound 10 turn pot to set output voltage up to ~420V. This output voltage feeds the gate of a 600V NFET, that operates as pass device. I blew-up two of these FETS due to the lack of a short circuit protection, but it shouldn't be hard to implement one.
For operation I feed the (series connected) HV secondary which is most suitable for the desided output voltage to the PS board, to reduce heat dissipation on the heatsink.
As artosalo said: working with NFETS can indeed make for quite a compact build.
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
Old 11th March 2013, 06:09 PM   #6
I really don't want to build a PS.
Old 11th March 2013, 07:32 PM   #7
tomchr is offline tomchr  Canada
tomchr's Avatar
Finding a power supply that will meet all your needs will likely be a challenge. Maybe someone knows of an old tube supply that'll work. But I suspect you'll end up with one supply for the high voltage and a couple for the various filament voltages.
A Sorensen QRD 20-4 would be ideal for filaments. I have a QRD 40-2 (40 V, 2 A). I think I paid an entire $30 for it...
The B+ supply, I'd make from a HV transformer and a variac like Boywonder suggests. It takes about 15 minutes to solder the rectifier parts together and strap them to a piece of plywood. BAM! Done.
~Tom
Sizzling Summer Sale going now through August 31st, 2017: Modulus-86, Modulus-286, HP-1, DG300B, and more are all on sale.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 11th March 2013, 07:32 PM   #8
What is the difference between Heath IP-17 and SP-2717A ?
Old 11th March 2013, 07:34 PM   #9
Since you put it that way, I might do that.
Old 11th March 2013, 07:40 PM   #10
lexx21 is offline lexx21  United States
I have a Heathkit variable supply myself. Tube regulated and works great. I recapped it and replaced a few resistors when I got it. I also had to retube it as there were a few bad tubes, but now it works like a champ.
If you do get a Heathkit, I would suggest that you add a choke that can handle 200ma. The output isn't "dead quiet" as you would probably like, however it does get the job done until you want to build your own supply for your amp.
Bench Power Supply: What to look for ? Which one to get ?Hide this!Advertise here!
Bench Power Supply ilardi Power Supplies 1 14th September 2012 08:34 PM
Building a bench power supply Bunnfactor Power Supplies 12 11th November 2010 01:03 PM
My new bench power supply Circlotron Equipment & Tools 7 28th April 2003 03:29 PM
bench power supply jethari Parts 1 14th March 2003 05:31 PM
My bench power supply.. deepanger Solid State 71 18th February 2003 07:56 PM
Copyright ©1999-2017 diyAudio
