Anyone here use or heard these tubes, I am told they rival the 45 type tube but with more power???
#2 |
Interesting topic. I thought about a 50 amplifier as well. The new production SG50 is a really fine tube ans just round ~50$ (Shuguang SG-50 new Hi-Fi vacuum tube)
Problem is...sadly...the max. grid resistor is only 10k. So forget about about a nice old globe triode driving it directly. Either interstage or Cathode/Source/Emitter follower (=Power Drive). A good high-gm pentode, a mosfet and a 50. All directly coupled. Would yield a nice, unusual amplifier. Far away from the mainstream "Sakuma Style".
Терпенье и труд все перетрут
#3 |
Thought I would share this with you since you were kind enough to reply.
#4 |
Jcmusic
I have started to plan a 50 se these days can you share some info about your setup? Best regards Vegard |
#5 |
| Lafayette TE-50 Tube Tester | denny9167 | Tubes / Valves | 0 | 2nd May 2011 12:03 AM |
| Question - Type 19 tube | mc352 | Tubes / Valves | 9 | 21st April 2011 05:16 PM |
| New Production Shuguang Type 50 Tubes | korneluk | Tubes / Valves | 14 | 22nd December 2007 05:31 AM |
| How lucky are we? TJ type 50 triode to be made. Make your preferences known now! | jusbe | Tubes / Valves | 3 | 16th July 2004 05:18 PM |
