diyAudio Sponsor
Old 27th January 2010, 02:36 PM   #21
TheGimp is offline TheGimp  United States
TheGimp's Avatar
If you are running a Single Ended output, maybe. If you are running Push Pull, no you will need a phase splitter.
Most EL34 guitar amps are PP.
What are you hoping to build?
How much power?
Etc?
Old 27th January 2010, 02:41 PM   #22
davew is offline davew  United Kingdom
Thanks for the quick reply, I am hoping to build a single ended EL34 stereo amp.
Old 27th January 2010, 03:28 PM   #23
Sorry I never mentioned wattage, I am hoping to get 5+ watts from the final amp. My goal is more a first hifi starter project with parts that are reasonably to hand. If I use the Nina preamp I have all the valves that I need.
Old 27th January 2010, 04:12 PM   #24
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Originally Posted by Mike C View Post
When I started this project, my wife Janet said she didn't know why I was bothering as she didn't think it was possible to improve on what I had.
I wasn't too sure myself to be honest. Anyway, Janet is now convinced.
Hmmm... Who is Nina, if wife's name is Janet?
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 28th January 2010, 10:03 PM   #25
I had in mind something along the lines of the output stage of this design using the nina preamp instead of the 6sl7. I would welcome any comments as to the practicality of this idea.
Stereo Single-Ended EL34 Hi-Fi Amplifier
Old 17th March 2012, 01:22 PM   #26
Default E80CC in parallell mode
Hi Mike.
Long time no see on DIYaudio. Are you still alive?
I am about to built up your NINA preamp. For a better stereo separation, I want to use one E80CC for each channel, and run both E80CC-triodes in parallel-mode. Besides the better stereo separation, it will also halve the noise, and double the output current.
Now I need your help. Do I have to change any resistor-value, if I run them in parallell?
This question also goes out to all other DIY members who are interested.
Kind regards,
Max
Old 18th March 2012, 02:59 AM   #27
TheGimp's Avatar
davew,
If you want to run EL34 SE triode mode you will bias around -12.2V. and you don't want to go beyond -1.3V on g1 according to the data sheet (300V B+).
Given this, you only need 10.9V peak to drive it. (Pretty easy drive).
The proposed circuit should meet this requirement without difficulty.
I haven't looked at gin of the input, but yo will need considerably less than a gain of 10 to drive it from a typical line output.
Cambridge Audio CD5 output stage (circuit diagram) 316a Digital Source 0 15th May 2007 04:57 PM
Sony XA5es analog stage circuit georgehifi Digital Source 4 22nd August 2005 09:25 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Nina Simone Audiofanatic Everything Else 2 22nd April 2003 06:50 PM
Page generated in 0.09613 seconds (77.99% PHP - 22.01% MySQL) with 11 queries
