4xKT88 into Hammond 1650T, what am I missing? - diyAudio
Old 8th March 2013, 11:07 PM   #1
funk1980's Avatar
Default 4xKT88 into Hammond 1650T, what am I missing?
After a lot of reading and studying schematics (and tickering with pre amps), I thought I had the basiscs down for my first class AB1 ultra linear 4x KT88 into a Hammond 1650T OPT build. My goal is between 100 and 120 watts of power, which I assume is realistic.
For some reason, after drawing all the load lines (1/2 OPT impedance for class A part, 1/4 OPT impedance for class B part, shifting up class A line for bias point), my calculations show I've only got about 81 watts of power. HT will be 500V, fixed bias around -58V, which should, according to other builds I've found, be plenty for the 100W+ goal.
In my noob-ness, I offcourse might have made some errors. Any insight is welcome.
edit: I've attached the curves with loadlines. Tubes are paralleled, so Ia should be doubled.
Old 8th March 2013, 11:26 PM   #2
funk1980's Avatar
And while writing the 'edit' I might have answered my own question. For power calculations, I used around 430mA instead of the doubled 860mA. Although RMS power would then be 172W... I'm lost.
Old 9th March 2013, 12:28 AM   #3
GoatGuy is offline GoatGuy  United States
GoatGuy's Avatar
Lol... and you're worried about the difference?
The acoustic difference between 120W and 81W is only 10log(120/81) = 1.7 decibels ... in other words, almost inconsequential. I know you're trying to get all the design stuff right (laudable, I might add!) through use of curves and load lines, but really what you're going to end up doing is putting a variable bias on the tubes (though exotic... one for each tube, with separate grid-feed caps to isolate the relatively different DC bias voltages), and using a well measured cathode resistor of low value (on each KT88), measure the voltage across that cathode resistor, use ohm's law, and back-calculate the current flow. Nominal without a signal.
Adjusting the bias to get each KT88 to somewhere between the 1/10th and 1/2 nominal conduction level (follow your curves!). Then, start with some nice clean music source (or you could go signal-generator and sine waves + oscilloscope), and measure the CATHODE RESISTOR voltage (again). Why? Well because its going to be close to ground (safe), and because you know the value of each tube's resistor, you'll be able to balance the current quite nicely. And set it to the nominal value afforded by your load curves.
NOTE that in doing this, you need a 4 ohm or 8 (or whatever!) resistive load on the output transformer. This is to burn up the power that otherwise would reflect back as reverse EMF, driving the high voltage at the KT88 anodes much higher than your specification. You don't want much of that, for the life of the tubes, and your safety.
In the end, graphs and load curves get you "to the ballpark". Real tubes, with real differences in manufacturing, different days of make, different diffusions of helium through the glass-metal electrode seals, different batches of oxides for the cathode, and so on ... simply will need you to balance things by potentiometer. Carefully. Very carefully. And the load curves tell you "kind of where we should be".
Never had an amplifier that EVER "hit it" on the dot when everything was spec'd in advance, plugged in, and turned on the first time. Not even very close.
GoatGuy
Old 9th March 2013, 12:35 AM   #4
GoatGuy's Avatar
PS: these "low value cathode resistors" can be something that'll give enough DC voltage with the expected current, to give you 3 digits of precision on your digital meter. Most meters of any quality today are happy measuring down to sub-1-volt and giving 3 digits. Therefore ... if the current is expected to be (say) 100 milliamps nominal (per tube, though -58Vg1 and +500Va yields like 50ma for Svetlanas) then you might want to use a 2 ohm resistor. Bypass it (or not, it won't really make much difference) with a 2000 uF 25 volt electrolytic. actually, don't. To finally "hear the full sound", just short out the cathode resistors (in place, with a bit of bypass copper wire!), to see the difference, once the biases are set.
You're welcome.
GoatGuy
Old 9th March 2013, 01:13 AM   #5
funk1980's Avatar
Thanks for the extensive reply! That's a lot of useful info that will be very helpfull in the next design stages. And I will take it to heart all this theory is a guide and not an exact real world outcome .
A few questions rise though; In my second post, I concluded the power ouput wasn't 80-something watt, but actualy 172. Enough to seriously saturate the xformer I assume. I forgot the use the double plate current in my calculation because of the paralle tubes, but please correct me if I'm wrong.
If my calculation of 172 watt is about right, then I wonder why there are so many schematics with similar tubes and xformers ratings. Is the excess of power used the provide negative feedback or is there another reason for this 'mismatch'?
Old 9th March 2013, 04:18 AM   #6
45 is offline 45  Italy
45's Avatar
Attachment 334811
You don't get 120W because you didn't build the composite plate curves of the push-pull amp and thus the right 1/4 load-line. Have a look here for instance:
Part 3 - Of Loadlines, Power Output, and Distortion
Old 9th March 2013, 02:02 PM   #7
funk1980's Avatar
Thanks, but I have to disagree. Merlin Blencowe and Morgan Jones, two authors I hold in very high regard, both agree composite curves are somewhat 'overkill' for drawing the power stage loadlines. Reasons being a speaker is not pure resistance and valves are not perfect. Treating half the PP output as single ended and then converting the outcome to full PP requirements is enough to create a basic picture. And this is supported when drawing up the loadlines with the given values on e.g. the Genalex KT88 datasheet for the AB1 ultra linear fixed bias configuration (98W vs 100W given in the sheet).
So the question still stands, why are there so many PPP designs with 1650T (Z=1900 a-a) type configuration and 4 KT88's while the power outputs from the valves will far exceed the xformers ratings when pushed to full signal swing?? Headroom? Keeping away from 0V on G1? Margin for NFB??
Old 5th July 2014, 04:57 PM   #8
claudiomas's Avatar
Send a message via MSN to claudiomas
[QUOTE=So the question still stands, why are there so many PPP designs with 1650T (Z=1900 a-a) type configuration and 4 KT88's while the power outputs from the valves will far exceed the xformers ratings when pushed to full signal swing?? Headroom? Keeping away from 0V on G1? Margin for NFB??[/QUOTE]
1650W also Z=1900ohm a-a, best whit this transformer???
I have both transformers Hammond 1650T and 1650W , so i send 608VAC 50HZ from mains power transformer to plate to plate , secondary 8ohm on 8ohm 250W resistors, by oscilloscope and voltmeter same result, 37,5 Vac for 1650T and 38,1 Vac for 1650W, waveform exactly the same ,no saturation at all!
overbiased
http://claudiomas.monsite-orange.fr/
Old 5th July 2014, 07:35 PM   #9
funk1980's Avatar
Are your values RMS, peak or peak to peak??
Old 5th July 2014, 08:38 PM   #10
claudiomas's Avatar
rms
overbiased
Am I Missing Something? amandarae Tubelab 7 16th November 2012 10:33 PM
4XKT88 drive Salas Tubes / Valves 44 29th June 2009 01:10 PM
What am I missing? jeff mai Parts 3 19th June 2005 09:41 PM
Wanted 2 hammond 1650T output transformers NotInTheMafia Swap Meet 0 4th April 2005 05:27 PM
am i missing something theChris Analogue Source 1 22nd June 2003 12:25 PM
Copyright 1999-2017 diyAudio
