Two electrolytic cap selection questions - diyAudio
Old 8th March 2013, 09:09 PM   #1
Default Two electrolytic cap selection questions
I'm wondering what the difference is between Low ESR caps and Low Impedance caps and which one would be best for power supply smoothing.
I'm guessing that audio grade caps are designed for signal applications like cathode resistor bypass or coupling. That a low ESR cap would be better in a low voltage filter or smoothing application like DC heater supplies. Is that a fair statement?
Old 8th March 2013, 09:31 PM   #2
jcx is online now jcx  United States
R is one component of Z
some tech choices that reduce one will reduce both - though not all (such as electrolyte conducitivity modifiers - which won't do much for L)
for linear PS, modern C are orders better than anything available in the heyday of tubes
Old 8th March 2013, 09:33 PM   #3
diyAudio Member RIP
There is essentially no difference between low "equivalent series
resistance" and low "impedance" capacitors, its just marketing
speil. There should be a difference between audio coupling caps
and power supply caps, as they do very different jobs, the ripple
rating is obviously far more important for power supply caps.
rgds, sreten.
Modern electrolytic high temperature caps for switching supplies
are far better than old power supply electrolytics, numbers wise.
Coupling caps - lots of opinions - not much fact - take your choice.
Panasonic seem to be a good bet AFAICT.
Old 8th March 2013, 10:14 PM   #4
it would seem it's two different was of saying the same thing. Take a look at the Z and ESR numbers in the exercise. in this math exercise, Z almost equals ESR. Kind of like say how hot is something vs how cold is something.
File Type: png Screen shot 2013-03-08 at 6.11.47 PM.png (86.5 KB, 162 views)
Old 9th March 2013, 06:47 AM   #5
rfengineer2013's Avatar
The impedance of a capacitor depends on the capacitance value, the equivalent series inductance (ESL) and the equivalent series resistance (ESR). The ESL is generally quite small and can be neglected at frequencies below a few hundred kilohertz.
Thus "ESR" and "Impedance" at audio frequencies are essentially equivalent - and lower is better for either term.
Aluminum electrolytics have reasonably good ESR, and there are special "Low ESR" aluminum electrolytics available (at higher cost, of course). Plus, they are readily available from any electronics parts source.
To improve power supply performance, the film-oil high voltage caps (so-called "motor run" capacitors) have probably the lowest ESR. Motor-run caps are sometimes used at the output of the power supply filter (after the choke, connected to the B+ output) to supply peak currents to the PA sections. They are, however, physically large, relatively expensive and have only modest capacitance values (10's of uF).
Generally, you would use aluminum electrolytics for most of your power supply filtering as they have reasonably good ESR and very good cost/size/capacitance. Throw in a motor-run cap on the B+ if you want, they will improve dynamic performance of the amplifier and look cool
Good luck.
Old 9th March 2013, 06:26 PM   #6
Thanks everyone. That was helpful information.
It's interesting to me that Nichicon offers several lines of high reliability, low ESR radial leaded caps HERE while their snap in line HERE doesn't push any as Low ESR or Low Z.
I seems like it might be more effective to achieve Low Z with say 3 - 100uf "standard" caps rather than 1 Low Z 330uf cap.
Old 9th March 2013, 10:10 PM   #7
funk1980's Avatar
Multiple caps in parallel to lower ESR is always good practice. Using another extra film cap of 100n in parallel with the big elco's is even better.
Electrolytic Cap Search Peter Menting Parts 3 5th May 2006 02:40 AM
can I use an electrolytic cap as coupling? Nordic Chip Amps 2 20th September 2005 09:12 PM
Electrolytic Cap Testing Giaime Parts 12 31st May 2005 09:42 PM
Panasonic electrolytic cap sma Swap Meet 1 1st June 2004 10:37 AM
Copyright 1999-2017 diyAudio
