diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   6П3С Plate Voltage (http://www.diyaudio.com/forums/tubes-valves/231458-6-3-plate-voltage.html)
N4BBQ 6th March 2013 12:24 AM
6П3С Plate Voltage
I have some of these and they sound good for the price. What are some different plate voltages you guys/gals are running on yours if you have them?
My SE pair in the living room is running somewhere about 260VDC.
Anyone easing them up near 350ish?
artosalo 6th March 2013 04:29 AM
6p3s is basically equivalent to 6L6GB or 5881.
I have used for years 6p3s-e in push-pull circuits with 450 V anode and screen voltage without any problem.
The dissipation power must be kept at max. 20 W.
N4BBQ 6th March 2013 01:11 PM
Well good. I'd looked over the data sheet but was still wondering about the quality of the builds. Then again, as cheap as those are, you can run them hard and not worry too much really.
Resources saved on this page: MySQL 18.75%
