ECF801 Triode/Pentode any useful application ?
Old 2nd March 2013, 10:41 PM   #1
payloadde is offline payloadde  Europe
payloadde's Avatar
Default ECF801 Triode/Pentode any useful application ?
There are some Triode/Pentode combinations like ECF801 / 6GJ7 in which the two tube systems share a common cathode.
Are there any known applications where both systems can be used in a circuit ?
audio, power supply or whatever ?
I mean aside from their original purpose as oscillator/mixer in a frequency changer or using just the triode or the pentode separately ...
Judge: This court appreciates that you invented physics, Mr.Newton, but unfortunately you can't have a patent on it.
Old 3rd March 2013, 12:39 AM   #2
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
how about a Radford phase spliiter?....Radford pentode-triode LTP splitter
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 3rd March 2013, 02:37 AM   #3
the_manta is offline the_manta  Germany
the_manta's Avatar
Paraphase/See-Saw is a good possibility. Since one system has 100% feedback, its parameters don't matter.
Терпенье и труд все перетрут
Old 3rd March 2013, 09:15 AM   #4
payloadde's Avatar
Yes, that may fit. Found this, think it's the same: New Phase Splitter
In this article the emphasis is more on phase stability.
I gave it a try but although I used ECF82 spice models I could not get symmetric output signals ... played varying plate resistors but could not get it right, yet.
Don't have model for ecf801 either.
Old 3rd March 2013, 09:44 AM   #5
payloadde's Avatar
so the 2nd (unity-gain) triode could be the pentode, right ?
The Valve Wizard
Old 3rd March 2013, 09:55 AM   #6
the_manta's Avatar
The Valve Wizard
It's up to you ! If you want high gain, use the pentode for the amplifying first stage and the triode as second tube (slave). Otherwise, vice versa
Old 3rd March 2013, 05:11 PM   #7
Ketje is offline Ketje  Belgium
Ketje's Avatar
The fact that you can't get the Redford symetric doesn't surprise me.
I don't like that circuit.
To use the ECL801 as a paraphase splitter try it like this.Didn't build it but looks promessing.
Mona
Old 3rd March 2013, 09:03 PM   #8
payloadde's Avatar
Yes, floating paraphase, I guess.
I like the split cathode resistor, makes it easy to match non-equal tubes.
Modifyed it a little, hooked up the pentode in triode mode. All I had to do is to change the upper cathode R to 220 and the lower R to 470 ohms. Et voilą - symmetric outputs.
Not that I need a phase splitter right now, but good to know ... maybe some day ...
ECF801 Triode/Pentode any useful application ?Hide this!Advertise here!
Pentode to Triode Switch Sherman Tubes / Valves 40 6th February 2013 01:06 AM
RIAA triode or pentode Gluca Tubes / Valves 45 20th December 2012 05:41 AM
Substituting Pentode for Triode slor Tubes / Valves 14 29th January 2010 11:32 PM
Triode connecting a pentode? Burnedfingers Tubes / Valves 15 3rd July 2006 06:10 AM
Pentode to Triode trick. Diy martin Tubes / Valves 4 7th November 2005 12:00 PM
Copyright ©1999-2017 diyAudio
