Baking Tubes Procedure - Help... - Page 13 - diyAudio
Old 8th March 2013, 04:20 PM   #121
radiosmuck's Avatar
The Workrite 4000 has 4 x 810 tubes. The arcing was caused by the wrong application, I was trying to glue very thin strips of bamboo.
I understand that RF gluing is not the same as induction heating but I'm guessing the interference is similar?
Old 8th March 2013, 04:33 PM   #122
Merlinb is offline Merlinb  United Kingdom
Merlinb's Avatar
Originally Posted by radiosmuck View Post
Unpaved roads in the UK in the 50's? What part of Fairyland are you from?
I think he means cobbled, rather than 'unpaved'.
Old 8th March 2013, 09:48 PM   #123
expert in tautology
bear's Avatar
It's essentially the same type of idea... slightly different application and different "business end" of the unit...
4 x 810 is a boat load of tubes... it doesn't matter what the arcing was caused by, just that IF and when it does happen, major interference is created.
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 9th March 2013, 12:07 PM   #124
Originally Posted by DF96 View Post
As precisely the same problem appears to be solved by the getter during manufacture, I assume the getter can mop up nitrogen OK. Metals do form nitrides! Argon maybe not.
You are absolutely right. I was thinking room temperature, but at high temperatures barium bonds with nitrogen to form a stable nitride.
So we can conclude that during storage, the barium getter will catch oxigen, but nitrogen gas remains present untill the getter gets hot enough to initiate the reaction.
This explains the improvement that MJ found in his baking experiments.
The question remains however, if using the valves in a regular circuit would not have given the same results.
Old 9th March 2013, 02:41 PM   #125
DF96 is offline DF96  England
If there is a lot of gas then there is a risk of thermal runaway or cathode damage under normal operation. Baking avoids this. Never tried it myself, but I can see that it might sometimes be useful.
Old 12th March 2013, 11:29 AM   #126
Thermal runaway, ok. But how often does this occur?
Except for '80s chinese power valves I have not seen valves running away.
I do have noisy old valves. Perhaps due to high gas that the getter can't absorb under normal operating conditions. Baking might improve those.
Preventive baking (doing so without testing for gas first), for me is overdoing it a bit. Not to mention introducing thermal stress that could have been avoided.
Old 12th March 2013, 12:45 PM   #127
Thermal runaway is often seen in smaller older power valves when they get gassy. EL41 often end their lives in this way.
Old 12th March 2013, 01:48 PM   #128
TheGimp is offline TheGimp  United States
TheGimp's Avatar
I had a couple of 6P1P-EVs go this way. I have not experienced any since I started baking them before powering them up (20 tubes).
Old 12th March 2013, 04:29 PM   #129
Good to know: I have collected quite a few years ago.
When I finally get to using them I will test and monitor them closely
Old 12th March 2013, 10:32 PM   #130
FullRangeMan's Avatar
Sorry my ignorance, but how is this gas test for tubes?? (small and power tubes).
It will be quite useful to me.
>Never go to a psychiatrist, adopt a cat or dog from the streets. On the streets pets live only two years average.
Baking a pcb for removing moisture gmphadte Solid State 6 9th November 2012 09:24 AM
Best procedure? martinschki Twisted Pear 2 27th January 2011 05:44 PM
amplifier .... procedure east electronics Solid State 12 26th May 2010 10:25 PM
Playmaster setup procedure PeteMcK Solid State 5 23rd September 2009 09:18 AM
Speaker design procedure maylar Multi-Way 18 29th January 2004 03:47 PM
Copyright ©1999-2017 diyAudio
