Tube Sound Processor - Page 2 - diyAudio
Old 28th July 2013, 05:49 PM   #11
tomchr is offline tomchr  Canada
tomchr's Avatar
There's a fair amount of tube emulation circuits showing up in guitar amps and such. Some of them are quite good.
There seems to be two different approaches:
- DSP modeling
- Solid state circuits that create a harmonic structure similar to that of a tube.
These models/emulators seem to do a good job of modeling the effects of the tube transfer characteristic, but often not such a good job of modeling the effects of OPT saturation, etc. For hifi purposes, it wouldn't surprise me if one could design a tube emulator circuit that would get you 90 % of the "tube sound" for 10 % of the cost of a tube amp.
A tube emulator still wouldn't be as pretty as a well-excecuted tube amp, though.
~Tom
Modulus-86: 40W/8Ω @ 0.000061% THD. HP-1: 3W/20Ω, 450mW/300Ω @ 0.000032% THD. DG300B and Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 29th July 2013, 10:50 AM   #12
ja2dhc is offline ja2dhc  Japan
Send a message via AIM to ja2dhc Send a message via MSN to ja2dhc Send a message via Yahoo to ja2dhc
I measured the distortion characteristics as shown in the
attached photo.
I use Class-D amplifier for the final power amp. This amp uses
Tripath's TA2024 with DC15V power supply.
THD =2%@1W is the worst data among my home brew amplifiers
as is a successful result of the objective of Tube Sound Processor.
'73 de JA2DHC[/QUOTE]
Old 29th July 2013, 11:04 AM   #13
Sprags is offline Sprags  United States
Originally Posted by ja2dhc View Post
What is the TUBE SOUND ?
That would be a shame if some lame developer thought they could develop an app to simulate 'tube sound' for an MP3 tune to be filtered through on an iPhone or iPad. And you could select what type of tube sound. Push-Pull KT88 or 6550, SE 300B or 2A3....hmmm. Don't get them started.
Old 29th July 2013, 11:20 AM   #14
Originally Posted by DF96 View Post
Some people like distortion and may call it 'tube sound'. They often deny this. They may obtain the sound they prefer by misusing valves, but possibly not realising that this is what they are doing.
Others like valves for other reasons, and know that when used properly their distortion is sufficiently low that it will be inaudible and so can be ignored. Mostly, they dislike 'tube sound' as a phrase.
Lets have two people who need glasses.
They are looking at a fine art painting.
One of them wears thick distorted glasses. This person is the tube sound.
The other person wears thin high tech contacts.
I would rather be the person with the high tech contacts that allows me to see the picture more the way its viewed with pure eyes, then with some form of distortion thats "Warmer" that technically, and logically, distorts the image.
Why would a distorted image be a better thing then an undistorted image?
You want accuracy, extremely low distortion, high response, hi fidelity.
Old 29th July 2013, 11:30 AM   #15
For the same reason as Monet's Water Lilies generates more emotion than the photograph of the same nature scene...
Old 29th July 2013, 11:34 AM   #16
Exactly. You want to look at the image with as little possible distortion between you and the image.
Adding distortion, even it it sounds more pleasing to the ear, is STILL ADDING DISTORTION.
Old 29th July 2013, 12:14 PM   #17
The relationship between Distortion and Sound is described
in the following article which is written by Pete Millett.
the Sound of Distortion
My most favorite Tube Sound comes from my 211 SET amp
with Class-A2. This amp was designed by me.
see: 211 SET
(sorry written in Japanese).
Today's sound processor aims to close to 211SET with sound.
Old 29th July 2013, 12:17 PM   #18
DF96 is offline DF96  England
Yes. Not me, though. Read what I said.
Unnecessary, given the distortion from transducers. Low, yes; extremely low, mere specmanship. Pursuing one parameter to the nth degree will usually, in real engineering, mean too much compromise on other parameters.
Old 29th July 2013, 12:22 PM   #19
Sorry i generalised the parameters that a hi-fi person wants.
There is a whole whack of numbers in the parameters of an audio amp. You either want zero, 1, or infinity for each one of those parameters.
I understand that transducers cause distortion. You cant escape that, but thats no reason to accept distortion in an amplifier, then call it "tube sound".
Old 29th July 2013, 01:00 PM   #20
Gain? Typically around 20.
Bandwidth? Must be restricted at both LF and HF ends to avoid problems - only a fool wants a 'DC to daylight' amplifier, unless he is running off batteries in the middle of a desert.
Output impedance? Zero could increase RF pickup on cables by making them a better resonator.
No, your approach (if you really believe what you said) is naive and oversimplistic.
Need a good Sound Processor. crashman20 Digital Line Level 0 21st November 2012 04:26 PM
Alpine H800 sound processor harmon_bro Digital Line Level 1 6th May 2012 06:14 AM
surround sound processor using a PIC BarryD54 Digital Source 0 7th July 2008 09:11 PM
Behringer Tube Ultrafex T1954 Sound Processor, Anyone Use? DreadPirate Instruments and Amps 0 1st February 2007 12:53 PM
Sound Blaster Live Processor audioaction Parts 7 29th July 2003 08:18 AM
Copyright 1999-2017 diyAudio
