GU50 Screen Driven, DC Coupled - diyAudio
Old 28th February 2013, 07:02 PM   #1
Default GU50 Screen Driven, DC Coupled
My new idea with GU50. Screen driven and DC coupled. Is that possible?
Very first schematic:
Old 1st March 2013, 05:10 AM   #2
artosalo's Avatar
It is possible, but screen drive is not very linear and high driving level is required.
With 100 Vpp the output power is some 3,3 W (2k5 OPT), THD = 6 %
With 240 Vpp, 13 W, THD = 14 %. Distortion is mainly 2nd harmonic.
All the above values are from LT Spice simulation.
Old 1st March 2013, 05:18 AM   #3
TonyTecson's Avatar
it's been done here....EL36: Applications in Audio
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 1st March 2013, 08:10 PM   #4
Ketje is offline Ketje  Belgium
Ketje's Avatar
By connecting the cathode-resistor of the second triode to the first triode's cathode you get a positive feedback.The portion of feedback has to be less then the amplification of the first triode or else the circuit will oscillate.
Mona
6GB5 and Variants as Screen Driven Amps wrenchone Tubes / Valves 67 3rd October 2016 11:29 PM
Has anyone screen driven an EL84? Lingwendil Tubes / Valves 11 22nd April 2009 03:04 AM
Screen driven output stage nhuwar Tubes / Valves 2 1st December 2008 05:10 PM
6JN6 screen-drive (g2 driven) plate curves? GordonW Tubes / Valves 26 23rd April 2008 01:56 PM
Screen driven EL36 / 6CM5 /PL36 /25E5 Tubes4e4 Tubes / Valves 2 26th February 2006 12:00 PM
Copyright 1999-2017 diyAudio
