Designing an Interstage Transformer - Page 12 - diyAudio
Old 7th March 2013, 06:29 PM   #111
TheGimp is offline TheGimp  United States
TheGimp's Avatar
We had some stripper in the navy that would remove epoxy and any thing else it touched. It was a yellow/green slimy compound.
Old 7th March 2013, 06:39 PM   #112
Originally Posted by popilin View Post
Because through the pores, you lose insulation, moist air has a breakdown voltage of about 900 V.
Glass ε > 4 , uralane has a dielectric constant similar to Teflon, so the mix isn't a good deal.
Tell me, please, I will use a mask.
Yes moist air is a problem but it will be a problem with any material and increases as ε approaches 1.
Why does the glass and thinner have to matched dielectric constants?
I still have some of the stripper but not sure if the bottles are still labelled with pn and mfgr (20 years old). I can check tonight and that will give me a full day to think about giving you hazardous material info (someone needs to look out for you).
-Antonio
Old 7th March 2013, 08:59 PM   #113
popilin is offline popilin  Argentina
popilin's Avatar
Tell me its name, please.
Not if you do the windings as I do, look at post#59.
The electric field "see" different dielectric constants, then there is no a homogeneous field, then capacitance will be not homogeneous.
-Antonio
Well, if classified information is fine, if you can pass me by PM.
I do not suffer from insanity, I enjoy every minute of it. - Edgar Allan Poe
He has the most who is most content with the least. - Diogenes of Sinope
Old 7th March 2013, 09:33 PM   #114
TheGimp's Avatar
I don't remember the name, but it contained DMEK and MEK if IIRC.
Old 8th March 2013, 02:33 AM   #115
TheGimp's Avatar
Most of the rail is cut. I need to remove the rivets from another section to finish the rest of the peices.
Old 8th March 2013, 03:46 AM   #116
popilin's Avatar
Already taking shape, I like it.
I have the impression that you plan to do a lot of transformers.
Old 8th March 2013, 04:01 AM   #117
TheGimp's Avatar
If I can find a source for EI cores. bobbins and end bells I will do some experimenting. Yes.
If it works out I plan on replacing the AC motor with a stepper motor and adding a second stepper with a lead-screw for wire feed traverse.
Old 8th March 2013, 04:55 AM   #118
lakeside's Avatar
I have been planning on winding my own transformers also and will be following this thread with great interest. Here is a source for bobbins, channels, and end bells.
Transformer Components
I haven't been able to find a source for small quantities of laminations. I was thinking of trying C-cores.
Magnetic Cores - In Stock
Old 8th March 2013, 01:16 PM   #119
TheGimp's Avatar
I looked at using C cores till I checked the price of the banding tool and bands. Kind of pricy.
I wonder if Zip Ties could be used for assembly?
Old 8th March 2013, 01:37 PM   #120
Banned
I don't know what is so pricy....
Did you look here?
http://www.arzner.de/website/admin/c...preisliste.pdf
Reversing Interstage Transformer HP8903B Tubes / Valves 19 10th May 2012 05:36 AM
Interstage Transformer Questions galac Tubes / Valves 6 30th July 2011 05:54 PM
Inverted Interstage Transformer NickC Tubes / Valves 4 6th January 2011 12:57 AM
Is this a good interstage transformer? m6tt Tubes / Valves 3 5th January 2011 11:14 PM
interstage transformer effindi Tubes / Valves 8 10th November 2009 01:51 PM
Copyright 1999-2017 diyAudio
