Designing an Interstage Transformer
Old 7th March 2013, 01:48 PM   #101
popilin is offline popilin  Argentina
popilin's Avatar
Originally Posted by esltransformer View Post
Normal commercial available nomex has not a very low dielectical constance as far a a know. Mostly it's between 3.5 and 4.5. Nomex is available in many different qualities and the harder its pressed the higher the ε is. It can be up till 8! There is a quality unpressed nomex with a ε=1.3 however this is not standard available. If anybody knows a suplier please send me a pm.
http://www.osdasrl.com.ar/pdf/tec410.pdf
I do not suffer from insanity, I enjoy every minute of it. - Edgar Allan Poe
He has the most who is most content with the least. - Diogenes of Sinope
Old 7th March 2013, 01:55 PM   #102
esltransformer is offline esltransformer  Georgia
Banned
Originally Posted by popilin View Post
i would like to have nomex 411
Old 7th March 2013, 02:02 PM   #103
popilin's Avatar
Even better, ε = 1.3 @ 1KHz
http://www2.dupont.com/Energy_Soluti...nloads/411.pdf
Old 7th March 2013, 02:07 PM   #104
Banned
I know it is better but who sells it and what are the costs?
I know many nomex surpliers sell laminated nomex ( mylar or kapton). These nomex are worse.
very good is also paper ε=2
Old 7th March 2013, 02:12 PM   #105
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
I used to buy at "Electro aislante" in Buenos Aires, they had a shop at Av. San Juan but then moved to Av Entre Ríos.
Only problem is they are real *Industry* suppliers and demand a commercial CUIT (Argentine IRS Company ID number) to sell to you.
Get a friend to "lend" you their number.
My IRSA wholesale wire supplier also has some Nomex thicknesses available, you can buy "black" (no papers) from him:
ABRAHIM EMILIO ALAMBRE DE COBRE ESMALTADOS
CHILE 639, 1098 BUENOS AIRES | Teléfono : (011) 436 163 66
Not that much problem with papers, if you pay cash, but they heve no In ternet page, you must go there "in person" and see what they have available.
They fear robbery , so you will have to call them, make them trust you, and probably talk a lot through a 2" hole in their bullet proof door before they open it.
And even so, they may not sell you at all.
Tell them "Fahey de La Boca" is your friend and told you to buy there.
And even so they may ring me to check I know you, so send me a mail a few days before, just in case.
Old 7th March 2013, 02:17 PM   #106
popilin's Avatar
Sorry, I do not sell NOMEX and my provider is a "Kiosk" seedy, in Córdoba city.
NOMEX 410 is something like laminated, is "calendered"
Paper is good dry, what about varnish or moisture ?
Old 7th March 2013, 05:03 PM   #107
magnoman is offline magnoman  United States
I would think in order to get dielectric constants approaching 1 you need a very porous material (mostly air). In lieu of the expensive materials such as expanded teflon and nomex why not just use a glass cloth electrical tape (thermosetting or apply a thin layer of uralane to the cloth) ?
There used to be at least one chemical stripper for the poyimide wire (worked great) but given its health and environmental concerns I would strongly avoid it (now wish I had as well).
-Antonio
Old 7th March 2013, 05:10 PM   #108
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
If it doesn't occupy too much winding window (space at bobbin), you can try it.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 7th March 2013, 05:35 PM   #109
I have, many times. My experiences are for very different applications hence different goals and constraints, just figured its worth putting out there.
-Antonio
Old 7th March 2013, 06:05 PM   #110
popilin's Avatar
Because through the pores, you lose insulation, moist air has a breakdown voltage of about 900 V.
Glass ε > 4 , uralane has a dielectric constant similar to Teflon, so the mix isn't a good deal.
-Antonio
Tell me, please, I will use a mask.
Designing an Interstage TransformerHide this!Advertise here!
Reversing Interstage Transformer HP8903B Tubes / Valves 19 10th May 2012 05:36 AM
Interstage Transformer Questions galac Tubes / Valves 6 30th July 2011 05:54 PM
Inverted Interstage Transformer NickC Tubes / Valves 4 6th January 2011 12:57 AM
Is this a good interstage transformer? m6tt Tubes / Valves 3 5th January 2011 11:14 PM
interstage transformer effindi Tubes / Valves 8 10th November 2009 01:51 PM
