testing tubes for shorts - diyAudio
Old 27th February 2013, 03:14 PM   #1
Default testing tubes for shorts
came across this circut....looks simple enough. if one were to add mil=amp meeter connection points in series with the pilot lights.....would it allow to measure for leaks as well? any other diy circuts out there for shorts and leaks?
File Type: jpg 10232322-short-circuit-of-electron-tube-test-kldguitar.jpg (16.8 KB, 105 views)
Old 27th February 2013, 06:32 PM   #2
Rundmaus's Avatar
6V will be too low to measure leak currents, as the leak resistances are usually still in the high k-ohm range...
Greetings,
Andreas
Old 27th February 2013, 07:12 PM   #3
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Inplace of pilot lamps, U can use neon lamps in series with a high value resistor and higher voltage outputs at transformer winding to see leakages. See the radiotron's book for some circuits and considerations.
If anything can go wrong, it will.
If anything just cannot go wrong, it will anyway.
Old 28th February 2013, 12:20 AM   #4
Ok, so maybe 180v and some of those neon bulbs
Old 1st March 2013, 08:52 PM   #5
Location: Near Eindhoven, the sanctum of the pentode. and among that other things.
Send a message via Skype™ to v4lve lover
Yes, that is a better idea. i did the same thing to. used it in my homebrew tube tester.
My circuit consists of A 230volt neon tube. whit a 100n capacitor in series shunted whit 4M7. fed off 205Vac..
the capacitor is to stop the tube from conducting current, acting as a half wave rectifier.
works really well. flickers under 2M resistance. and glows brightly under 500k.
already found tubes whit shorted grids.. cathode shorts and a lot more faults.
my tester has a test switch whit 10 positions 2-9 test leakage/shorts and position 10 test anode current
cheers.
V4lve
testing tubes johnny audio Tubes / Valves 5 28th November 2012 08:01 PM
Testing valves/tubes Joe of Loath Tubes / Valves 4 18th January 2010 07:53 PM
Testing for tube shorts Zero Cool Tubes / Valves 3 31st May 2008 09:48 PM
-----testing Tubes---- ICARE Tubes / Valves 0 26th June 2003 02:38 PM
Testing Tubes Rino odorico Tubes / Valves 2 4th October 2002 07:31 PM
Copyright 1999-2017 diyAudio
