Suggest a preamp project for me. - diyAudio
Old 27th February 2013, 04:52 AM   #1
djef is offline djef  United States
Default Suggest a preamp project for me.
I'm looking to make a preamp from scratch to drive a pair of MC30s. Would anyone have a suggestion for a circuit? I really just need it as a phono pre with maybe some simple tone controls.
Old 27th February 2013, 04:17 PM   #2
I built the preamp from DIYaudioprojects.com I used primarily recycled parts, all of which i sourced and soldered together into a nice little line stage. I am very happy with it and I am planning on building the RIAA phono pre from the same designer. If desired, tone controls can be added but I would build it as is and see how you like it first. It uses 12AX7A variants so tubes should be no problem to source or roll. If you are handy at all you can make these little things perform. Hope this helps.
Old 27th February 2013, 06:34 PM   #3
Miguel Lopez's Avatar
Have you tried with the pre-amplifier of the Mullard 5-10 design?
Mullard 5-10. Ten Watt Amplifier
Old 27th February 2013, 08:37 PM   #4
evanc is offline evanc  United States
Location: New Jersey. About 1 hour from NYC and 1 min. from the beach
My first decent system had a pair of mc30s. For me they had plenty of power with just a passive preamp. Maybe just build a phono preamp and box it with an attenuator and an input selector. Check out the Simplistic njfet riaa by salas.
Evan
http://www.evancotler.com
Old 28th February 2013, 03:30 AM   #5
This looks like great project. I might do this. This is for my phono setup however. Will I need to incorporate RIAA circuitry somehow?
Old 28th February 2013, 04:47 AM   #6
Chris Hornbeck's Avatar
The Mullard is certainly classic, but not really a preamp in the modern sense of the term. It's from the days of ceramic phono cartridges, crystal AM tuners, and a very high required sensitivity. Today a preamp, for those who still spin wax, has two parts, a phono equalizer (that brings the tiny output from a modern phono cartridge up to line levels) and a line stage (that selects between various line level sources, has gain control and sometimes tone controls, and usually has some flat gain of its own, maybe 10 or 20 dB).
For DIY and especially for a first project, these might be considered to be two separate gigs. As has already been suggested, the line stage might be made "passive", without a gain stage, just to get your feet wet, leaving room to add the gain if desired later. The MC30 has a high sensitivity, so is a good candidate for this.
A good phono stage is much more difficult to get right, so might be saved for later. Just some thoughts.
All good fortune,
Chris
Old 11th May 2013, 10:23 PM   #7
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Trafomatic phono reference one apparently is wonderful. One of my next projects. Schematic on sixmoons.
Sent from my GT-N7000 using Tapatalk 2
Old 11th May 2013, 11:23 PM   #8
Soonerorlater's Avatar
As a starter I'm thinking of building Eli Duttmans' version of the RCA phono schematic.
When white moths were on the wing,
moth-like stars were flickering out,
Old 12th May 2013, 03:10 AM   #9
A phono preamp is not a simple project. Definitely look before you leap.
JMO, the tweaked RCA setup is good, without being highly complicated. Those folks who've built the setup are happy. I've uploaded a graphic for a cost effective PSU that's quite suitable.
Contact member Jeff Yourison to obtain the benefit of his construction experience.
Eli D.
Old 12th May 2013, 10:21 AM   #10
mach1 is offline mach1  Australia
mach1's Avatar
. Trafomatic phono reference one apparently is wonderful. One of my next projects. Schematic on sixmoons.
I wonder why the designer uses parallel resistors everywhere, with 4 on the 6N6P cathodes?
'Symmetrical equations are good in their place, but 'vector' is a useless survival, or offshoot from quaternions, and has never been of the slightest use to any creature.' Lord Kelvin
Suggest me a preamp for my F4! giacomo_pagani Pass Labs 185 7th February 2015 03:10 PM
pls suggest a project lordearl Tubes / Valves 7 22nd March 2010 03:55 PM
suggest about 9002/vt202 preamp please jp74 Tubes / Valves 0 1st June 2009 08:17 AM
Preamp suggest, please. kacernator Tubes / Valves 18 27th February 2008 08:29 PM
Please suggest a preamp HiFiNutNut Solid State 5 28th May 2004 07:08 PM
Copyright 1999-2017 diyAudio
