rebuilding 3tube zenith amp
Old 26th February 2013, 03:38 PM   #1
knockbill is offline knockbill  United States
knockbill's Avatar
Default rebuilding 3tube zenith amp
hi guys,
new here, this is my first post,,,, i just rebuilt my first amp,a little zenith 3L03, new caps, resistors, polarized cordset & stdp switch.... i redressed the filament leads, and put in a 3rd stage filter, to help get rid of teh hum,,, it works pretty well, the amp has crisp highs, but not a lot of bass, and it has some distortion, at high volume levels...
the distortion is what i'm trying to reduce now,,,the tubes all test very good ... i modded teh amp a little,,, replaced teh .01 coupling caps with .068, in hope of getting more bass, it helped a little, but seems to have maxed out there...
i replaced teh 150 ohm K resistors with 180's,,, and dropped teh 270K coupling resistors, to 220K,,,tried as low as 120K, to get more negative bias, but it didn't seem to change after 220...
i would appreciate any help i can get to get rid of teh distortion, or at least to understand why its there,,,
i posted teh original schematic,,, and teh chassis..
thanks for reading,
regards,
john
(schematic removed by moderators for blatant safety issues)
Old 26th February 2013, 04:18 PM   #2
overtheairbroadcast is offline overtheairbroadcast  Canada
From my quick look at the schematic and not knowing even 1/10th as much as the other regular posters here at diyaudio, I can say that it is pretty underpowered but nonetheless pretty cool.
You are getting all your power from 110 V from the wall, with no power transformer required (the tubes are at 117V according to the schematic), so I wouldn't think that you would be able to get massive amounts of volume from this setup because of small tubes, low B+ voltage, SE set up, all usually means low power.
You might not get much bass response because this looks like it was set up for playing records -- I was told that there is something about records not having very low frequency range because of something or another, (I am not very knowledgeable when it comes to this stuff, I can build it, and I am still alive) only as I don't see an auxillary in and only the phono cartridge in.
The only thing I can think of is upgrading to beefier output transformers (but that requires math and money to figure out what would be appropriate). It might not be worth it, but see what the experts here have to say.
What kind of speakers are you using? Are you using other than the original ones which are rated for 9 ohms and probably as old as the hills?
Old 26th February 2013, 04:28 PM   #3
On Hiatus
SY's Avatar
FIRST THING- install an isolation transformer. This setup is dangerous enough that we have a specific rule on this forum about showing anything with a direct mains connection.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 26th February 2013, 04:47 PM   #4
knockbill's Avatar
i am running it thru an isolation transformer... plugged into a gfi receptacle... i have been a licensed electrician for over 40 years, and am aware of teh hot chassis design,, same as most AA5 radios.... this is the only tube amp i have, and am using it to learn about tube circuits,,, i have plans to restore, or build my own 5 tube amp, i found a schematic to use....
if i can't discuss it on your forum, please let me know... i will remove the info in the post...
thank you,
john
Old 26th February 2013, 04:52 PM   #5
kevinkr's Avatar
Since you've clearly stated that you use an isolation transformer this discussion can continue.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 26th February 2013, 05:00 PM   #6
knockbill's Avatar
hi thanks for your reply,
yes, it is from a zenith portable phono,,, i have it connected thru a cd palyer, now,,, and used it with a casstte player, also...
i was told that different OT's may help teh bass, but i don't know how to calculate what i would need...
i'm running thru my main speakers(12"-4" tweeter, in a bass reflex enclosure)... it came with 3x5" but sounds much better pushing teh bigger speakers,,, also, teh output of teh amp is 3.2 ohms,,, my mains are 8 ohm...
regards,
john
Old 26th February 2013, 05:08 PM   #7
knockbill's Avatar
ok,,, well, i see teh schematic was taken down,,, am i allowed to pm it to someone who may offer to help me out?
tahnks,
john
Old 26th February 2013, 05:10 PM   #8
kevinkr's Avatar
Might help to post a hand drawn schematic of the amp which must clearly show the isolation transformer as part of the circuit.
Edcor makes some nice output transformers, but I suspect even their small ones might be a bit too large for this tiny chassis.
I would enjoy as is, and if you really like tube sound consider this: Simple SE
George is quite active here and a friend to many - I can highly recommend this as a project for a tube newb.
Performance will be immeasurably better, providing real bass, dynamics and detail with enough power to get some decent levels out of your speaker system.
Old 26th February 2013, 05:13 PM   #9
kevinkr's Avatar
tahnks,
john
No problem there, but you could draw it yourself and snap a picture with your digital camera, not brilliant but it would work to get the information across.
Old 26th February 2013, 05:49 PM   #10
knockbill's Avatar
ok,,, heres a pic of the amp and teh iso trans is under the table...
i tried to post schematic pics i took with my camera, they came out to blurry to read...
thanks, also for teh link to teh "simple se",,, i have a 6v6 amp in mind, i have the tubes, and a chassis i built, i'm not really interested in pc board construction...
i sure hope this thread gets pointed to teh distortion problem i first asked about!!!!!
regards,
john
rebuilding 3tube zenith ampHide this!Advertise here!
modifying zenith 7d31 amp console jcricket Tubes / Valves 3 9th March 2014 04:35 AM
Zenith Console find, amp suggestions? Eratosthenes Tubes / Valves 8 28th August 2008 05:20 PM
zenith amp diesel_tech Tubes / Valves 6 22nd October 2007 01:34 AM
I'm rebuilding my amp Lisandro_P Everything Else 2 4th July 2002 08:53 AM
