Old 25th February 2013, 10:57 PM   #1
Default Phono connection for pioneer sx34b
Hello everyone, I got a pioneer sx34b receiver recently, everything seems to work fine except when I switch the nob to phono without any source connected, a loud buzz came on. What can I do to get rid of this buzzing noise. I want to connect my Philip 212 with it. Thks in advance.
Old 2nd March 2013, 11:48 PM   #2
Could this loud buzz noise caused by one of the bad tube ? Does anyone here have the pioneer sx34b schematic ?
Old 3rd March 2013, 12:03 AM   #3
vinylkid58's Avatar
I have a low rez non "b" schem. Does the buzzing go away when you plug the turntables IC's into the receiver?
jeff
Old 3rd March 2013, 12:17 AM   #4
Try placing shorting plugs in the phono I/Ps. If that eliminates the buzz, you are already good to go. Remove the shorting plugs and connect the TT up.
I've uploaded a schematic of sorts. You'll have to dig around the WWW with google to get a version with more detail.
Eli D.
Old 3rd March 2013, 04:19 AM   #5
Thank you Jeff and Eli... For the quick response!
But here the thing, I have try several of plug shortening techniques but the hum still remain. What causes this? All other source inputs on the sx34b work good except for the phono input. While I am suspecting a bad tube or ic from the receiver, is there other way to troubleshoot the phono input ?
Old 3rd March 2013, 05:16 AM   #6
Not shortening, shorting. Get an inexpensive pair of RCA plugs and solder a short length of wire between the center pin and the outer shell. Install the shorting plugs in the phono I/Ps and see what happens. You must remember that the phono preamp section is designed to work with mV. level signals. You could be picking up EMI from the environment. This kind of trouble also occurs with SS phono preamp circuits.
Eli D.
Old 3rd March 2013, 05:26 AM   #7
vinylkid58's Avatar
Is the humming/buzzing in one channel, or both?
jeff
Old 3rd March 2013, 01:25 PM   #8
Hi Eli... Yes I inserted the shorting pin between the L/R phono input of the reciever, but the hum still there and its on both channel.
Thks again for ur both quick reply.
Old 3rd March 2013, 01:56 PM   #9
cogsncogs's Avatar
Not shorting pin, but shorting plug. Using a shorting pin you've connected the L and R inputs together, that's not what you want to do. A shorting plug shorts (shunts) the individual L and R inputs to ground.
Pioneer A400 Volume pot, connection advice needed data Solid State 4 10th November 2011 05:09 PM
Pioneer A300R phono stage stevew7280 Solid State 2 16th June 2011 07:28 PM
Phono Cable Connection Nightpuma Analogue Source 3 27th October 2010 07:11 PM
Improve my old Pioneer Phono Stage? Ecaroh Analogue Source 5 1st February 2010 06:32 PM
How long can an RCA phono connection be? Cal Weldon Multi-Way 6 16th March 2004 11:01 AM
Copyright ©1999-2013 diyAudio
