diyAudio Sponsor
Old 24th November 2003, 03:07 AM   #11
diyAudio Senior Member
fdegrove's Avatar
ahem... hmmmm.. upssss... i didnt know bout that........plans change, then... what about 5687 with parallel sections , 300V, 2 x 12k anode + 132 R cathode resistor(4V bias), unbypassed (drew this on the curves)... zout would be (???) ~1.8k
Don't // unless you bloody have to for crying out loud.
Frank
Old 24th November 2003, 10:50 AM   #12
Aiace is offline Aiace  Italy
Default Too much tubes
Are you sure you need V2 ?
You should try to listen your circuit with anly V1: I bet you'll love the sigle stage common catode amplifier
Bye
Aiace
Old 24th November 2003, 08:28 PM   #13
costiss's Avatar
ill try it... in both configurations.. generally, tubes are said to operate best in higher currents and voltages... larger energy management?... i dont know.. this 5687 seems to be nice... (too much of it).... any european resource for jan - phillips ones?
i am currently using 60,000 uF of capacitance in my preamplifier..
Old 25th November 2003, 02:19 AM   #14
fdegrove's Avatar
Leaving contradictions aside that tube and the 6922 are opposing sonically, one too strident mostly, the other too dark sounding according to taste.
Frank
newbie - learning bout vinyl c0redumpt Introductions 2 27th May 2009 02:41 PM
How 'bout them sig lines? Pano The Lounge 4 6th December 2008 05:56 PM
I need an amp,quick! How 'bout this? iUSERTLO72p Solid State 7 26th January 2008 06:57 PM
a few questions bout components troublecomes Chip Amps 5 1st December 2005 07:40 AM
Page generated in 0.08121 seconds (74.27% PHP - 25.73% MySQL) with 11 queries
