Loadlines for Parallel SE outputs
Old 24th February 2013, 02:22 AM   #1
Richard Ellis is offline Richard Ellis  Argentina
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Default Loadlines for Parallel SE outputs
I'm putting together this PSE amp using the 12B4 doubled up running into an OPT at 2500 ohms. With only 170VDC for my B+, I get a really 'steep' loadline for the 12B4......my question is 'How does one do the DC loadline for "twin" ouput tubes.??? I,m trying to get a handle on how much current each channel will be drawing.
__________________________________________________ ______Rick.......
Old 24th February 2013, 03:16 AM   #2
DUG is offline DUG  Canada
Double your load impedance at half the total quiescent current.
Each tube will see half the total current and will only have to drive half the load: 2500 * 2 = 5000 ohms
The transformer will still operate at the same quiescent current.
Makes sense?
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 24th February 2013, 11:35 PM   #3
jazbo8 is offline jazbo8
jazbo8's Avatar
Slightly OT, how does one go about calculating the bias for three DIFFERENT power tubes in SE, like Palmer Triple SE
I think the OPT has three separate primaries, so each tube type could see the correct impedance, is it just that simple?
Jaz
Old 26th February 2013, 03:36 AM   #4
How the Palmer Triple SE works is your guess as much as mine.
Could be all three tubes work the same way with similar bias points...or maybe that is the only change between the three...different cathode resistors.
Let us know what you find out.
Loadlines for Parallel SE outputsHide this!Advertise here!
paralleling computer power supply outputs: can they be connected in parallel... jarthel Parts 7 12th December 2012 09:13 PM
Diamond buffer headphone amp- can I parallel outputs? Fast Eddie D Headphone Systems 11 17th August 2012 03:25 PM
Parallel outputs? jerryo Class D 2 2nd December 2009 07:22 AM
Parallel LM4780/3886: leave away those 0,2Ohm between the outputs? Bassterror Chip Amps 13 11th August 2006 04:10 PM
Parallel SE vs. Single SE Output Question valveitude Tubes / Valves 19 4th May 2005 05:36 PM
