| diyAudio Sponsor | ||
hi everybody,am planning to change amp and i would like to go for tube amps. could anyone recommend some brands that i could look into. the power i want is in the range of 120 - 150w. any recommendation would be highly appreciated and pls. indicate if you had experience in using the recommended amp especially the not so nice part like what you dont like about that amp. am not very interested with the good features like the what the manufacturer points out. they are all marketing hype. what am really interested is the down to earth assessment. also pls recommend tube pre-amps. am crossing my finger that whatever recomm you make is available here in my country. thanx in advance
"none but the brave deserves the fair" shakespeare |
#2 |
Have a crack at MacIntosh (US) ; I get alot of flannel in the post about their amps. However, the price may discourage you. There may be a sales office where you are.
There is also a Dutch make called Vandermelle or something sim. I have repaired too many of their amps so that gets cold water poured on. The other solution IS TO MAKE ONE. What construct ability do you have ? Are you ok with 500V DC and have access to test equipment and mechanical workshop ? Transformer manufacturers are around in the UK and US/Jp. In the UK you should be aiming for about £500 for two (stereo) 100W transformers suitable for KT88/6550 tubes. The 6550 is a poor mans KT88, but runs fine. 150W power bracket is serious stuff and ends up with multiple pairs or triplet output stages. The cost goes up also square law. richrich |
#3 |
120-150W is a lot of power. Is this for a bar or something?
Normal listening reqires 1-10 watts usually, tube amps are best for this. |
#4 |
A 50 Watt tube amp can sound pretty loud, alot of people get on better with this than 100W.
If you change your mind, and go for construction, then the 3 stage GEC KT88-50W amp gives very creditable results. rich |
#5 | |
#6 |
All is very quiet...I wonder if he has changed his mind.. yet ?
#7 |
there is no reason to use that much wattage for a tube amp.. are you trying to run the whole venue from your guitar amp??
if you want one that sounds good check out this. http://home.cfl.rr.com/dbhammond/FireFly_sch.gif http://dhammond_1.tripod.com/FireFlyBoost.mp3 http://dhammond_1.tripod.com/FireFly.mp3 |
#8 |
hello hello,hey guys am still here i know that the power i mentioned was high but i could settle for 50w to 80w. this amp is going to be my personal use in my music room. my budget for the preamp and amp is between $2,500 to $3,000. i know prices of good and reliable units are really high. so i have prepared for that. pls. give more infos, thanx
#9 |
You want a recommendation. How about a pair of Dynaco MKIIIs off ebay and rebuilding them and a PAS preamp to go with it.
That's a good old 60 watt mono amp with great mod potential. The PAS preamp is a classic also with a ton of different mods out there. You should be able to get those for much less than the dollar figure quoted and have money leftover for good tubes and upgrades. If you want new all I can say is good luck and go listen to some equipment if you can. It's the only way to really tell if you will like it or not. Myself, I'd buy the old stuff and work it over. It's just more cost effective and quicker too. Later BZ
What ever makes the tunes flow |
| rectifier tube recommendation please | gary h | Tubes / Valves | 5 | 9th July 2008 02:39 PM |
| tube CD player recommendation | shaunly | Analogue Source | 9 | 3rd March 2008 05:09 AM |
| need diy tube preamp (line-stage) recommendation and general tube advice | Musiclover4 | Tubes / Valves | 15 | 24th November 2005 02:19 AM |
| Tube Recommendation | FrankRoss | Tubes / Valves | 23 | 6th June 2004 06:19 PM |
| Page generated in 0.12076 seconds (72.37% PHP - 27.63% MySQL) with 10 queries |
