6v6 SE kit - any good? - diyAudio
Old 20th February 2013, 08:23 PM   #1
Default 6v6 SE kit - any good?
Is there anybody out there who had built those cheap kits (6v6 SE) from Siliconray or Wowhifi. How does the amps sounds and perform. And how does the supplier/seller perform. 240 USD for a complete kit, -sounds to good to be true?
Old 21st February 2013, 01:39 AM   #2
heavil is offline heavil  Russian Federation
heavil's Avatar
Link?
Per set for the amplifier without housing and transformer, this price may well be adequate.
Old 21st February 2013, 10:45 AM   #3
The price is for complete kits, including housing and transformer, -the whole lot!! Thats why i was asking this forum for any who eventually bought and built these amps. See www.wowhifi.com or www.siliconray.com. Single ended 2x5w up to 2x12w.
Old 21st February 2013, 11:59 AM   #4
Siliconray looks decent but strangely shipping for kits is twice what they charge for assembled amp so you may be better off with SA-22 Single Ended HiFi Tube Amplifier SA-01 - Boards | Kits | Components | Modules | Tools at $280 + 45 shipping and then modify it if required.
On the other hand, you may be able to source slightly better parts within Europe for the same money and build one of the form's favourites but likely without the enclosure included in the sum.
Old 21st February 2013, 12:34 PM   #5
There is the Vendor Forum with Silicon Ray in it. Check out what others are saying about his stuff over there and other things encountered. This will give you a better overview of his products. so far biggest comments are the shipping, but you are moving 40 pounds of material at times.
From the looks of it, talking to others in a few PM and emails, and from talking to the man himself, I think that his products are a cut above other Chinese manufacturers.
Old 21st February 2013, 05:34 PM   #6
Well I built the 6l6 version. I also built another SE 6L6 after that with all parts sourced local (USA) and I paid less with better sonics with the local build and I didn't have to wait months for the kit. That said it helped me as it was my first point to point build. So in that respect it was a good experience. If you are getting into point to point and have limited or no build from scratch experience, it's a good place to start. The amp I built actually sounds fairly decent. Expect 5w/ch for the 6L6/6P3S version (which is cheaper I think).
Good beginner kit since it has a nice SS chassis but the iron is nothing to write home about. This kit actually exceeded my expectation as I thought I'd be getting a decent chassis for $140 and I'd have to source everything else... I learned a lot but I also have experience building other electronics. You need to feel comfortable with +400v and know how to stay safe.
Bob
Old 21st February 2013, 07:02 PM   #7
Thanks Bob for your interesting reply. Im quite experied in recond. I recently fixed up a Dynaco St-70 in it sounds and looks great. My aim for a kit is that it provides a layout for the components and also pictures that shows where to put what. Just like in the original building manual for the st-70. There are a lot of good shematics on the net and i can easly get the components and hardware here in Sweden. The problem is, and i think i share them with others who want to build, there are wery few layouts provided along with the shematics. The ideal kit for me should be a amp designed as a guitar amp where the components are lined up on a eyelet board, then connected to iron and tubes etc. Better than what iwe seen in some p2p, where caps and resistors more or less are hanging in the air. A amp kit designed like this would be a hit amongst diyrs. Skl.BoC.
Old 21st February 2013, 08:29 PM   #8
With this kit you get a schematic, chassis (nice one), parts (some not so good) and transformers/choke. Layout is up to you. You could do your own turret board if you like, but it's all point to point. You gotta come up with your own wire scheme, that's where some of the creativity comes in. How are you going to lay it out and make it work.
Bob
Old 22nd February 2013, 12:40 PM   #9
sled108 is offline sled108  United States
sled108's Avatar
I built SiliconRay's 6V6 Pre-Amp which has the same Chassis as the Amp...It is as Bobrown says, you get a Box O' Parts and a Schematic (In Chinese)...But, it's all there and it Works...
Let's Talk 1516-6V6 SE 5Wx2 Hifi Tube Amplifier Kit tomlang Siliconray Online Electronics Store 3 12th February 2013 09:20 PM
OPCs The WIRE Latest Generation - PCBs for sale (4x BAL-SE, 1x SE-SE, 1x PSU KIT) fualcr Swap Meet 0 15th February 2012 11:39 PM
6V6 SE VS ECL85 J_Hart_14 Tubes / Valves 22 14th December 2010 01:15 PM
SE 6V6 cathode resistor value bereanbill Tubes / Valves 7 24th May 2009 04:11 PM
6V6 vs EL84 SE UL AudioGeek Tubes / Valves 10 3rd February 2006 11:05 AM
Copyright 1999-2017 diyAudio
