My new GU50 SE (all pentode)
Old 18th February 2013, 03:58 PM   #1
matejsirk is offline matejsirk  Slovenia
Default My new GU50 SE (all pentode)
This is my new SE with GU50. Idea is "stolen" from Wavebourn. I tried 6J9P and 6J49P as input tube and I found that 6J49P sound better. I got around 12W.
schematic:
amp:
Old 18th February 2013, 04:00 PM   #2
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Clean, very nice.
Old 18th February 2013, 04:29 PM   #3
artosalo is offline artosalo  Finland
artosalo's Avatar
Cathode resistor of GU50 not bypassed ?
Old 18th February 2013, 04:32 PM   #4
No, with bypassed I have to much gain and no difference in sound. I must find the right NFB resistor, but right now I am out of 110K-1M resistors.
Old 18th February 2013, 10:21 PM   #5
Ejam is offline Ejam  Australia
Default Power Supply Details
Matejsirk
Can you give some power supply details, maybe a schematic would be nice.
Old 18th February 2013, 10:30 PM   #6
Ketje is online now Ketje  Belgium
Ketje's Avatar
Doesn't 01 on 100k cutoff the bass to high?
Mona
Old 18th February 2013, 11:06 PM   #7
the_manta is offline the_manta  Germany
the_manta's Avatar
Mona
-3db is: Solve[10^5 == (1/(2*Pi*f*100*10^-9)), f] - Wolfram|Alpha
"No difference".....interesting. Pentode without cathode decoupling yields gigantic output resistance. What speakers do you use ? Open baffle ? With my bassreflex speakers this would be impossible.
Терпенье и труд все перетрут
Old 19th February 2013, 12:56 AM   #8
Paul Scearce is offline Paul Scearce  United States
Nice looking build, and I like the use of the regulated screen supplies. I am inclined to jump on the bandwagon suggesting a lower feedback resistor value instead of an unbypassed cathode resistor. By quick and dirty estimate, you are getting a plate impedance of around 4kOhm with the bypass and 10kOhm without it given the current feedback scheme.
Old 19th February 2013, 10:13 AM   #9
45 is offline 45  Italy
45's Avatar
It doesn't mean anything. A constant current ampifier can work as good as constant voltage (a typical solid state amp) or (quasi) constant power amp (a typical zero feedback DHT).
It's not about bass reflex or dipole. It's more about drivers. A constant current amp + drivers with a good self damping (in the good sense) just work fine.
Have you ever heard of Ultrasound?
Sito Ultrasound Main Frame
Have a look at their bass reflex loudspeakers and amplifiers. Although I disagree with the multipole concept, their standard bass reflex speakers with their high Zout amps sound very nice.
Old 19th February 2013, 03:22 PM   #10
Today I add 220uF bypass cap on cathode on GU50 and change NFB resistor to 110K. Sensitivity is now 1V eff.
My speakers are SCHULZ KSP 215K + NEO CD3.0 in TL cabinet. Crossover 5500Hz only coil for KSP and cap for TW. Sensitivity around 94dB.
My new GU50 SE (all pentode)Hide this!Advertise here!
GU50 SE vs 300B SE tube amp?? gaborbela Tubes / Valves 72 16th October 2014 02:27 AM
pentode in triode mode SE vs a DHT SE like 2a3/300b jarthel Tubes / Valves 67 8th July 2014 02:51 AM
My little SE with GU50 matejsirk Tubes / Valves 20 28th January 2012 04:27 PM
New GU50 SE: SRRP or Cascode for driver? Globulator Tubes / Valves 11 5th November 2010 07:15 PM
A small no-fuss pentode/pentode SE amp Tubes4e4 Tubes / Valves 13 1st January 2006 06:16 AM
Copyright ©1999-2017 diyAudio
