Heathkit XO-1 power cords - Page 2 - diyAudio
Old 21st February 2013, 11:13 PM   #11
Chris Hornbeck's Avatar
Is there a hole (about 3/8") on the back panel for the grommet? Can you post a picture of the whole back panel?
Banana plugs CANNOT be used for AC power. No way, no how. Think of the exposed (and exposable) voltages - it's a widow-maker.
All good fortune,
Chris
Old 22nd February 2013, 12:19 AM   #12
eyoung is offline eyoung  United States
eyoung's Avatar
It looks like it would be a good canidate for an IEC recepticle with some minor mods to the power entry hole....
E
"Lead me not into temptation...I can find it myself."
Old 22nd February 2013, 10:04 AM   #13
All good fortune,
Chris
The pic. posted is basically the whole back. There is no other receptacle of any sort other than what you see in the pic.
Tom b. 57
Old 22nd February 2013, 01:48 PM   #14
boywonder's Avatar
Tom B: There seems to be some confusion here.
Your picture shows two small round panel mount connectors, as well as an old 2 prong power out AC connector (no ground).
Your post has "power cords" in the title. It appears to most of the members that replied here that the 2 small round holes cannot be AC power connectors, as the mating connector would then have live AC mains voltage sitting on exposed male plugs, extremely dangerous and not likely.
Are the two round connectors some sort of signal connectors? Are these original or has this equipment been modified?
Can you post a picture of the bottom with the cover off? That would help alot at this point.......
Old 22nd February 2013, 11:05 PM   #15
Enzo is offline Enzo  United States
perhaps it would help if you were to open it up and find out the following:
1. Just what do the two banana jacks connect to, and are they in fact insulated from the chassis. They do not look stock, and are not in the schematic nor in photos of the intereior of other units.
2. Find the primary wires for the power transformer, and see what is connected to them.
This might be of use:
Electronic Crossover XO-1 Misc Heathkit Brand, Heath Co.; Be
Analysis Plus Power Oval 10 Power Cords $125 Only A Few Weeks Old! mister pig Swap Meet 1 1st June 2010 01:18 PM
Power Cords patherb Everything Else 6 9th March 2009 04:01 PM
heathkit crossover xo-1 / x0-1 problem SOFIA1999 Parts 0 12th November 2008 04:53 PM
Shunyata Power Cords.... Voltaic The Lounge 10 3rd July 2006 12:44 AM
power cords lopan Parts 9 16th September 2004 01:42 AM
Copyright 1999-2017 diyAudio
