Will this work as a heater for 300b? - diyAudio
Old 8th February 2013, 08:21 AM   #1
Green77 is offline Green77  Sweden
Default Will this work as a heater for 300b?
Hi all!
I have a TSE with 300b tubes that hum for the first 2-5 min when i power it on.
I have discust this with you people here before..but it's time to take care of it now
Today i use the 6,3v AC, make DC and regulate it with a AD1084 to 5V.
My plan is to do like this:
Will this work? Hopefully this will make it hum free..
Regards //Daniel
Old 8th February 2013, 08:46 AM   #2
euro21 is offline euro21  Hungary
Originally Posted by Green77 View Post
Will this work?
Maybe.
One side of 300Bs heater (thus cathode) are common. If this point is ground (negative bias on the grid), it will work.
IMHO 4700uF is too small. Try 15000uF - 1R -15000uF.
If later does not disturb you, don't worry about it.
Old 8th February 2013, 11:53 AM   #3
12E1 is offline 12E1  United Kingdom
12E1's Avatar
Correct. If using cathode bias, you need completely isolated transformer, bridge etc for each valve.
If the constant current circuit does its job, then 4700uF is fine. Reducing the ripple further on the input side to the LM317 will make a tiny difference to the current regulation which should be all but inaudible.
You should not place large capacitance after the regulator / resistor since this could create stability issues and will prevent the regulator from properly controlling the current. You should not think of this as a CRC filter.
@Green77 - circuit says LM317 - text says AD1084. I could not find data on the latter to check the details. LM317 would be OK provided that it was a suitable package and suitably coupled to a heatsink.
Old 8th February 2013, 12:15 PM   #4
Thanks for the replies!
I have fixed bias to the 300b.
My bad, i have ap1084 regulator today.
Regards. /Daniel
Old 8th February 2013, 12:28 PM   #5
12E1's Avatar
Regards. /Daniel
Fixed bias should be OK using a single transformer so long as one end of each filament goes to ground. AD1084 may be OK - I just had trouble to find a datasheet to check the resistor value for the current control.
Old 8th February 2013, 01:13 PM   #6
jrenkin is offline jrenkin  United States
I thought the TSE already used regulated filaments on the output tube.
What are you trying to accomplish?
Old 8th February 2013, 01:28 PM   #7
Yes, the TSE does. But when i build mine i wasnt abel to get the sharp regulator. So i build my one circut. With a volt regulator for 5v (ap1084).
/Daniel
Old 8th February 2013, 03:41 PM   #8
12E1's Avatar
I just found the data - the manufacturer's site was off-line earlier.
So the AD1084 is available in different versions. The circuit that you showed can work with the AD1084-ADJ part, but not with the AD1084-5.0. Which version of the AD1084 are you trying to use?
Since the AD1084 can pass high current it is important to get this right, or you could destroy the filaments in your tubes.
Old 8th February 2013, 03:46 PM   #9
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
It will work, but I used LT1084 regulator on my TSE 300B.
Old 8th February 2013, 04:32 PM   #10
Yepp, works when the tubes are hot after some min.
How about sound? Is the 317 ccs better heater then the volt regulator?
I read somewhere on the forum that the cap after the regulator could make the sound bad...
Regards //Daniel
Looking for 300B 2.5V heater vendor Raj1 Tubes / Valves 6 10th October 2008 10:23 AM
peak current 300B heater with start up Jaap Tubes / Valves 12 6th June 2007 12:47 AM
SMPS for 300B heater ? Jaap Tubes / Valves 9 25th August 2005 12:49 AM
300B mesh plate, 2,5 Volt Heater reinhard Tubes / Valves 6 2nd September 2002 01:54 PM
Copyright 1999-2017 diyAudio
