Will this work as a heater for 300b? - Page 3 - diyAudio
Old 9th February 2013, 12:43 AM   #21
tomchr is offline tomchr  Canada
tomchr's Avatar
...or use a switcher running off the 12 V winding. That's what I use.
~Tom
Modulus-86: 40W/8Ω @ 0.000061% THD. HP-1: 3W/20Ω, 450mW/300Ω @ 0.000032% THD. DG300B and Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 9th February 2013, 01:07 AM   #22
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Originally Posted by tomchr View Post
Yep. You can't generate 5 V from a 6 V AC transformer winding using a linear regulator.
I can. 6.3V+6.3V, pair of Shottky diodes, 15,000 microfarad cap, and MOSFET, getting 6.3V regulated and well filtered.
Here is 12.6V version attached, for 6.3V I use 5.6V Zener.
The Devil is not so terrible as his math model is!
Looking for 300B 2.5V heater vendor Raj1 Tubes / Valves 6 10th October 2008 11:23 AM
peak current 300B heater with start up Jaap Tubes / Valves 12 6th June 2007 01:47 AM
SMPS for 300B heater ? Jaap Tubes / Valves 9 25th August 2005 01:49 AM
300B mesh plate, 2,5 Volt Heater reinhard Tubes / Valves 6 2nd September 2002 02:54 PM
Copyright 1999-2017 diyAudio
