10M45S problem - Page 4 - diyAudio
Old 6th February 2013, 09:56 PM   #31
Yes, that sure is shown as a 100R. That's what I'm using now. Thanks for the article.
Originally Posted by jackinnj View Post
Old 6th February 2013, 10:02 PM   #32
ttan98 is offline ttan98  Australia
scott17,
I am thinking of using the current source in the same position as yours(the driving tube is a triode not a pentode like yours), do you use a heat sink on the 10M45? I am using about 2-3 mA though this IC and about 150V across it.
Old 6th February 2013, 10:12 PM   #33
Yes, I did use a heat sink. I'm not sure that it needs one at that current, but I erred on the side of safety anyway. I just cut a chunk off of an old CPU heat sink and tapped and threaded it. You can see them in this photo.
Don't be blinded by the LED bias circuit though!
Originally Posted by ttan98 View Post
scott17,
Old 6th February 2013, 10:21 PM   #34
One more thing. Don't forget that the heat sink will have the B+ voltage on it. So be careful.
Old 7th February 2013, 12:14 AM   #35
Scott17,
Thanks for info and warning. From your cct diagram, is the 100ohm and 1kohm positions interchange, i.e. your current cct diagram is incorrect.
Old 7th February 2013, 12:31 AM   #36
popilin is offline popilin  Argentina
popilin's Avatar
Since dissipation is small, no problem to isolate the device from heatsink with insulating washers.
Believe me, the temptation to touch a heatsink, is always stronger than our memory, and on your assembly would be a little dangerous.
I do not suffer from insanity, I enjoy every minute of it. - Edgar Allan Poe
He has the most who is most content with the least. - Diogenes of Sinope
Old 7th February 2013, 12:38 AM   #37
Scott17,
The drawing shown at post #20 is how it is now connected. 100R for the gate stopper, and 1K for the current set. The 1K is based on the calculation from the data sheet, and in my case it is correct and gives the correct voltage drop for my required current. The diagram is correct.
Old 7th February 2013, 12:41 AM   #38
Well, my memory must be better than yours then. I know not to touch it when it is on, and I can remember not to. Since I am the only one with access to it, it is perfectly safe and not dangerous at all.
Old 11th February 2013, 05:55 PM   #39
Everything works now. It was a reversed OT primary. I know I should have checked that first, but since one channel worked and the other didn't, I suppose I overlooked it at first. My mistake. Never trust the color code or drawing. Sorry to waste so many folks time speculating since it was such an easy fix. Thanks very much.
Here is the schematic.
Old 11th February 2013, 06:53 PM   #40
popilin's Avatar
Don't worry, can happen, Murphy lives...
The important thing is that you solved the problem.
10m45s Steven123 Tubelab 10 8th May 2011 11:39 AM
Ixys 10m45s theskintman Tubelab 0 31st August 2010 11:31 AM
Ixcp 10m45s Wombat 397 Tubes / Valves 14 4th September 2009 12:09 AM
Help needed with 10M45S integration . TugaTweaker Tubes / Valves 11 9th March 2009 07:33 PM
Wtb; 10m45s Cobra2 Swap Meet 9 26th November 2008 05:17 AM
Copyright 1999-2017 diyAudio
