I want to re-design the driver stage of the Dynaco MK3.
My idea is the following: - no pre-amp, (I have already too much gain from the phono) - volume pot 100k log - phase splitter is LL1545A - 6sn7 as drivers ( this is to be determined) - a good dose of global feedback (this is to be determined how it is applied) - kt88 in ultralinear with second grid 1k resistor with 40% taps. |
#2 |
That is a lot of effort for monaural sound. I buy mono LP's to hear Toscanini or CR Fine at work, but stereo is one of those improvements that I can actually hear. You sure you don't want to buy a new chassis and a pair of matching output transformers? KT88's are pretty big, and hot.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300 |
#3 |
#4 |
I have 2 and they are actually working. I would use something like 15 db of feedback.
I thought about this: 100k volume - 6sn7 cathode follower with active load 6sn7 this is going to a LL1545A transformer for creating a balanced output, the balanced output is feed to the long tail pair 6sn7 , feedback is applied to this part. |
#5 |
I was mulling over similar ideas, maybe without the input transformer. I'm thinking the 6SN7 won't have enough gain to apply global feedback, maybe consider 6922 or 6gk5?
#6 | |
The idea behind the input phase splitter transformer was my discovery that the long tail pair is far from perfect. I will draft a schematic... |
#7 |
Sounds cool! I'd like to see it.
#8 |
basically the idea is this one : Audio Virtual Systems very similar... I even use the same output trans...
#9 |
Hi, I did more research and found that I could connect the volume pot to a doubled 6sn7 in triode mode connected directly to a LL1660S connected directly to KT88...
The feedback would be feed to the cathode resistors 6sn7 cath. There would be 2 capacitors at the balanced ends of the LL1660S because I want to bias the tubes individually with grid bias. Shematic similar to the SUN audio amplifier for EL34 PP... LL1660S specifies 220 V R M S max |
#10 |
I just don't know for the feedback and values of resistors.
I am figuring out if it needs capacitors because the KT88 are biased individually per grid and it could upset the transformer ability to split the music if there is modulation and different fields. *** maybe I will abandon this idea and adopt this instead: input -- long tail pair -- capacitors -- KT88 Last edited by gabdx; 13th February 2013 at 12:26 AM. |
| Dynaco mk3 clone hum issue | gabdx | Tubes / Valves | 0 | 13th January 2013 12:58 PM |
| Musical Fidelity MVT mk3 preamp line-stage | rmgvs | Solid State | 31 | 1st March 2012 11:45 AM |
| FS: Welborne Labs Alan Kimmel Mu Stage Driver Kit for Dynaco ST70 ST-70 | e.lectronick | Swap Meet | 7 | 6th May 2009 03:30 PM |
| Why triode Mk3 is louder than stock Mk3 | Wieslaw Lipowsk | Tubes / Valves | 5 | 14th June 2007 01:18 PM |
| Dynaco SCA-35 phono stage. Don't understand it. | Bing Yang | Analogue Source | 1 | 16th August 2005 11:54 AM |
