New driver stage for dynaco mk3 - Page 2 - diyAudio
Old 16th February 2013, 03:22 PM   #11
gabdx is offline gabdx  Canada
I will try this out before going to transformer splitter...
I don't know which way to take 1, 2, 3 and the need for the capacitor on the grid 2. I learned that I could use feedback from the output transformer and send it to Grid 1 or Grid 2, but I ignore the pro or cons.
Old 17th February 2013, 05:32 AM   #12
artosalo's Avatar
No CCS will work without some bias voltage.
You should give positive bias to tubes or connect the lower end of the CCS to negative voltage instead of GND.
For example LM317 regulator works fine with some 20 V bias.
Old 17th February 2013, 12:20 PM   #13
Hi, I actually use figure 1 from lm334 with the positive voltage of the cathodes. I know it can be improved with thermal stability (figure 3) and it can oscillate if the stage overloads because not enough cathode potential will exist.
Old 20th February 2013, 12:36 AM   #14
I will use Grid 2 similar to LEAK amplifiers. Now about the values of resistors I have no clue to give me a start...
Old 23rd February 2013, 03:28 AM   #15
I just don't know for the feedback and values of resistors.
I am figuring out if it needs capacitors because the KT88 are biased individually per grid and it could upset the transformer ability to split the music if there is modulation and different fields.
*** maybe I will abandon this idea and adopt this instead: input -- long tail pair -- capacitors -- KT88
I will just do that without capacitors, 0 caps amplifier (haha 2 transformers) I saw that the transformers allow for indifidual biasing current to circulate in both half without any issues.
Dynaco mk3 clone hum issue gabdx Tubes / Valves 0 13th January 2013 12:58 PM
Musical Fidelity MVT mk3 preamp line-stage rmgvs Solid State 31 1st March 2012 11:45 AM
FS: Welborne Labs Alan Kimmel Mu Stage Driver Kit for Dynaco ST70 ST-70 e.lectronick Swap Meet 7 6th May 2009 03:30 PM
Why triode Mk3 is louder than stock Mk3 Wieslaw Lipowsk Tubes / Valves 5 14th June 2007 01:18 PM
Dynaco SCA-35 phono stage. Don't understand it. Bing Yang Analogue Source 1 16th August 2005 11:54 AM
Copyright 1999-2017 diyAudio
