diyAudio Sponsor
Old 19th November 2003, 01:45 PM   #11
diyAudio Senior Member
fdegrove's Avatar
I made seperate transformator only for heating and use Zn-Al protect tube for lead tone signal wire.
Separate xformers for the heaters is certainly a +.
Zn-Al protective tubing...not sure if that's effective and it could be the source of grounding loops causing hum.
In my amps there's not a single shielded wire and it's absolutely dead quiet.
pardon what mean BTW?
That means " By the way".
Lot's of people use acronyms for frequently returning word sequences.
ACRONYM FINDER
Frank
Old 19th November 2003, 03:30 PM   #12
arg_ is offline arg_  Greece
Do you mind sending me a copy or you could even post it here for future reference?
No problem, here it is
Numbers in blue is DC, red is AC at 1Khz. Of course these are to be taken as a general reference only and are valid for my configuration, measured voltages will vary depending on tubes, tolerances, power line voltage etc.
Jevta in case you've built the capacitorless version, did you have the chance to measure DC offset?
Cheers
Old 19th November 2003, 09:32 PM   #13
fdegrove's Avatar
Thanks, Argilis.
Hans,
Would you have a type number of those special Pana caps you used?
That is, if they're available outside of Japan...
TIA.
Frank
Old 21st November 2003, 03:29 AM   #14
Hi Frank,
Normally Panasonic capacitors have part numbers like EEGAA2D103FPE or something similar but the ones I use in my OTL have only these markings:
For OTL
250V 3300uF
- NEGATIVE
+85 C JAPAN
PANASONIC.
The 2200uF ones have same marking.
However I dont think these capacitors are that special as I achieved similar result in the amp I built for a friend using Panasonic EEG type caps.
I have made extensive measurement of frequency and phase characteristics of my amp and I found that there was a tendency for increased gain at low frequencies. This I have corrected for by introducing a phase compensating network. There could be a possibility that Andreas circuit has similar tendencies actually worsening hum when feedback is increased, I haven't checked this with Andreas circuit but as you can see there is a total lack of any frequency or phase compensating components.
Hans
Old 21st November 2003, 11:46 PM   #15
fdegrove's Avatar
Yes, it's not a circuit I'd build for myself unless I'd had a small lab at my disposal.
The Technics bootstrap drive is interesting though for future OTL amps.
For your info, my amp uses the Radford type of fase splitter using a ECF802.
It measures fine and sounds fine too.
Frank
Parallel LM3886, input ground, power ground, safety resistor and oscillations. markiemrboo Chip Amps 5 9th August 2007 03:50 PM
DC filament ground and high voltage ground mikeyho Tubes / Valves 0 15th September 2005 05:52 PM
Chassis Ground = Circuit Ground --> Problems? rhildenbrand Pass Labs 5 23rd April 2004 01:08 AM
does connecting mains ground with circuit ground create a ground loop? jarthel Everything Else 0 25th June 2003 12:55 PM
Should I directly connect my signal ground to chassis ground? Bricolo Solid State 3 28th February 2003 05:31 PM
Page generated in 0.09836 seconds (80.04% PHP - 19.96% MySQL) with 11 queries
