Old 27th January 2013, 10:06 PM   #1
wrenchone's Avatar
Default Monster Hammond Output XFMRs
I just picked up a pair of fairly massive output transformers from some Hammond instrument. The number on the transformer is A0-30072-1. From my preliminary searches these may have been used in a bass cabinet of some sort. Does anyone have an associated schematic?
Old 27th January 2013, 10:16 PM   #2
wrenchone's Avatar
Hmmm. just answered my own question. These things came out of a Hammond E-100 organ and drove two speakers with a tapped secondary, with a HF crossover cap in series with one output. I nabbed a copy of the schematic. The amp used a pair if 7591As - I might settle for 6P3S-Es instead.
Old 28th January 2013, 07:08 PM   #3
tricomp is offline tricomp  Denmark
It's actually quite a bit more powerfull.
It also ran the Reverberation PP-Amp.
Take a closer look at the schematics.
rgds,
/tri-comp
Old 28th January 2013, 07:31 PM   #4
wrenchone's Avatar
Not too sure about that, as there are 3 output leads on the transformers in question, and the reverb amp shows 2 output leads on the transformer. I'll take more time to figure them out when I actually have a project for them. I'll also check my home copy of the schematic, as it has more resolution.
Edit - I see what you're talking about, now, as what looked murky in the small schematic was a crossover for another speaker output. Having said that, the amp only uses 7591As. I figure the extra transformer mass must be for bass extension.
Hammond 1620 output transformer brainwreck Swap Meet 1 12th February 2010 09:32 PM
Hammond Vintage two 6v6 output transformer FranStar Swap Meet 0 17th November 2006 10:11 PM
look at this rotel moster guys lt cdr data Solid State 3 22nd May 2005 04:44 PM
Hammond 1627SE Output Transformers Carrier Bag Man Swap Meet 4 17th October 2004 05:39 PM
Jensen JE-112-PC line output xfmrs MRehorst Swap Meet 0 24th July 2002 04:13 AM
Copyright ©1999-2013 diyAudio
