6A3 / 6B4G Design - Page 3 - diyAudio
Old 10th May 2013, 06:02 PM   #21
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Define safe.
What bias scheme?
Considering it is only 0.5% (15.075 vs 15.000) over recommended operating condition plate dissipation I would think it would be safe.
There is a recommended op of 325V at 40mA.
Is the 335V actually from anode to cathode or is it Va with respect to ground?
Old 10th May 2013, 07:31 PM   #22
Palustris's Avatar
"I'm trying to run Vak 335V, 45mA for Kenrad bi-plate 6B4G. Is it safe for those tubes ?"
That totally depends on how you define "safe." The tubes at that operating point will not burst into flames, however, the recommended Max plate voltage is 250V so the tubes will not last as long as they would at the recommended operating point. I have used 275V in PP and have a Thordarson amp with a pair of 6B4Gs operating at 300V. You don't say whether you are operating in SE or PP. If you look at your load line you will see that at 335V in SE you will get a lot of 2nd harmonic distortion, while in PP you will be operating in AB2 and the distortion should cancel.
In SE I would stick close to the recommended operating point of 250V @ 60mA. Again, look at your load lines and you will see exactly why: you will be operating in a more linear part of the curves.
Old 10th May 2013, 09:38 PM   #23
45 is online now 45  Italy
45's Avatar
Originally Posted by TheGimp View Post
So far I have not assembled the amp.
I'm trying to limit the design to two stages total.
I'm testing potential driver tubes in a lab configuration with adjustable cathode resistor (fully bypassed) and Gyrator anode load. This is buffered by a FET source follower, which runs into a step attenuator (0, -20dB, -40dB) and then a Twin T filter and differential buffer to drive my sound card.
Right now I'm sorting through potential driver tubes.
I would use 1/2 6SL7 per channel CCS loaded (LND150 cascode below or just at 1 mA or IXTP01N100D cascode for 2 mA or more) RC-coupled to 1/2 6SN7 per channel wired-up as DC coupled cathode follower to the 6A3 or a FET source follower. This way one can swing more (or a lot more) than 90V p-p with considerably less distortion in comparison the 25-30% shown above (if the supply voltage is enough) and much better drive. In the end the power supply is just as important as the amplifying stages themselves for best result....
For the cathode follower you just need +/- 170V and 15K cathode resistor in order to run it at about 8 mA and get about 45V bias for the 6A3 (have a look at the classical Audio Note schematics).
Old 10th May 2013, 09:49 PM   #24
45's Avatar
If you want go for more than 300V plate voltage then you can try with the 6C4C that is rated for 360V max. You can also run it at 16-17W plate dissipation without any problem. Actually I have also run some good Chinese 2A3's (Golden Dragon and Billington Gold) at 275V/60mA for about -51V bias. They guy who's using that amp has never got any problem. I would say that it has been running flawlessly at least for 5000 hours now!
Old 10th May 2013, 10:22 PM   #25
45's Avatar
At 275V/60mA with 3.5K load I found better results. I got less distortion and practically the same efficiency in comparison to 250V/60mA with 2.5K. If you stick to class A1 the max Pout will be just under 4W (without transformer loss). The efficiency is very similar. However I found THD to be around 3% only for 4W out. If you have a good driver like a DC coupled CF or FET follower you can easily get 5-to-6 W at the onset of clipping.
Old 12th May 2013, 03:56 AM   #26
Define safe.
What bias scheme?
Tks Gimp,
I use fixed bias, Vg ~ 60V at that ponit, 5K OPT. My schema is coming soon
Old 12th May 2013, 04:28 AM   #27
I mean " safe" is long acting without problem.
Remember that data we used read is for single plate tube. Bi-plate tube have much more power. 2A3/ 6B4G seems to get twin plates of 45 tube inside.
I build this pair of OPT for single end: 5K/ 8 ohms, Fe 32mm x 46mm. I intend use them for small tubes, eg 4P1L or 45. So the airgap is just 0.1mm and fixed by glue , I think they cannot run over 40-42mA at idle. See 335V, 40-42mA in loading of 5K still have linearity much
At 250V, 60mA of 2A3 in my friend's amp, sound is a bit slow and dark. And I don't like it.
Gimp, What is your amp like ?
Old 16th May 2013, 08:15 AM   #28
Here are the loadline of 2 operation points and the results. You can choice which is convenient for yourself
Old 16th May 2013, 10:32 AM   #29
TheGimp's Avatar
tcqanh,
I have not built my amp yet. I am working on a coil winder to make a set of inter-stage transformers to use in it.
Old 17th May 2013, 12:56 AM   #30
tcqanh,
I finished my power amp 6B4G SE from modifying 4033L ampli. I use 6S45P-EB for driver. AC hum is now a bit high due to AC heater, 10-11mVac. My plan is building of separate heater power transformer and 4P1L for driver tube.
IT is my favorite.
6A3/6B4G/6S4S(2A3/2S4S) project widowmaker Tubes / Valves 35 21st August 2016 08:56 PM
6A3 test, what am I doing wrong? TheGimp Tubes / Valves 23 24th November 2012 04:11 AM
Finally built my 6SL7, 2A3/6A3 amp mig-ru Tubes / Valves 39 19th September 2011 08:21 PM
help me design an input stage for 6b4G PP AudioGeek Tubes / Valves 11 2nd September 2005 07:48 AM
driver 6a3 2a3maniac Tubes / Valves 2 21st January 2004 07:25 PM
Copyright 1999-2017 diyAudio
