| diyAudio Sponsor | ||
Hi all,
I find some transformer manufacturers claim that their transformer (power trans, output trans and choke) are using Z11 or Z14 silicon steel. What is Z11 or Z14 mean? (I know it is according to some standards, but any more details?) Z11 or Z14 is better? Thank you for your help in advance. Tuna Fish
#2 |
Z11 mean old specification from nippon steel material
equivalent to 35Z155 present specification thickness 0.35 coreloss 1.47 w/kg at 1.7Tesla 50 Hertz equivalent to M6 AISI |
#3 |
How about Z14?
Does Z11 better or Z14 better? |
#4 |
Hello
Z11 is the lowest grade in group grain oriented core that is high efficiency material mostly used to make big transformer like distribution transformer and power transformer. Z14 didn't have in system. May be you mis remember. Because ther are another one group of silicon steel call non oriented silicon steel. that one mostly use in small transformer, motor core, stepping motor, balast core and also Choke,and etc. one of this they have H14 or 50H400 in present . This one coreloss=4.0 w/kg at 1.5 tesla 50 Hz Of course Z11 is better than H14 |
#5 |
Account Disabled
hi,
pls see the message & information of the core. cobalt lamination. http://www.vt4c.com/bb/viewtopic.php?t=115 cobalt & other lamination steel detail. pls visit www.diyaudiocraft.com. homepage>more info> to see the base. Lamination Materials We have tried to assemble in one place both an overview of all the commonly used lamination materials, as well as some data which may be useful to designers of electromagnetic equipment. Select an article from the list below... Cold Rolled Motor Lam | Silicon Steel | Nickel Alloys | Cobalt Alloy for our double c-core lamination. http://www.vt4c.com/bb/viewtopic.php?t=155 thanks thomas |
#6 |
Account Disabled
one of member talking about the different performance & different spec of different core.
Z11,Z14, EI Cobalt, amphorous core too. Pls visit & take a look. http://www.vt4c.com/bb/viewtopic.php?t=149 many data contain. thanks thomas www.diyaudiocraft.com |
#7 |
Account Disabled
hi all,
pls see the 0.22mm thickness 78% permalloy lamination. the black one Orient-HiB 0.15mm. thanks thomas |
#8 |
hi,
can you tell how they were able to color the laminations black? thanks
Placebo medicine works best when the doctor believes in it too. Next best is when the doctor is good at pretending to believe in it.DF96 |
#9 |
Account Disabled
hi joans,
the silver colour lamination because of contain Nickel. Nickel alloy will more shininy with more nickel contain. the black colour orient HI-B because of the different grade, physical property as cool roll & heated roll. Different flux density will have different. But in my knowledge thinner lamination will be better because of less core lose. for more information pls visit my site to proto lam. www.diyaudiocraft.com Click more info & see the bottom. U can see the detail of different lamination. thnaks thomas |
#10 |
Thank you Siu Siu Man.
Nice to meet another Hong Kong DIYer in here. |
| Transformer rewinding material | elseif | Parts | 2 | 5th September 2008 01:30 AM |
| Trying to find specs on transformer core material | nhuwar | Tubes / Valves | 7 | 16th June 2007 02:29 AM |
| Transformer potting material?? | ThSpeakerDude88 | Tubes / Valves | 9 | 6th August 2006 11:14 PM |
| Brace material - various woods, steel etc. | Circlotron | Multi-Way | 22 | 2nd December 2003 04:31 PM |
| Stupid question: Where do you find the steel transformer plates... | hoxuanduc | Chip Amps | 21 | 26th May 2003 09:52 PM |
| Page generated in 0.11258 seconds (78.49% PHP - 21.51% MySQL) with 11 queries |
