Marrantz Model 9 Transformer Buy
Old 10th March 2013, 03:53 AM   #11
prairieboy is offline prairieboy  Canada
prairieboy's Avatar
Nice looking trannies. I might suggest, instead of potting them due to possible heat build up, to use transformer covers. Various vendors in China seem to have them (one example: Audio Catalog) or an idea I saw elsewhere on this site, was to use a hammond cast aluminum case. Invert the case, don't use the lid, and fasten from below. Just a thought ...
Old 10th March 2013, 04:03 PM   #12
mr2racer is offline mr2racer  United States
mr2racer's Avatar
I found some enclosures that would work but they would cost about $180 with shipping. I can build four of them for about $20 that will look just as nice. As for heat? The power transformer is built for 400ma operation and with a quiescent current of 275ma they should run fairly cool?
Old 10th March 2013, 04:24 PM   #13
tomlang is offline tomlang  United States
tomlang's Avatar
Is it possible to post a connection diagram of these output transformers with reflected impedances? I would also like to know the dimensions of these, thanks.
Also, you purchased yours from Heyboer without the bell covers and pieces of angle instead, correct? I would assume Heyboer has bells to fit these if one desired?
Old 12th March 2013, 02:33 AM   #14
mr2racer's Avatar
Default Transformer Diagram
Actually the OPTs came with endbells but I removed them so they could be potted. I'm trying to find the output transformer diagram.
Old 12th March 2013, 03:24 AM   #15
mr2racer's Avatar
Default Output Transformer
A better copy.
Old 14th March 2013, 03:14 PM   #16
tomlang's Avatar
Thanks for the information, very interesting. The challenge will be to use the extra secondary windings for proper feedback.
Old 15th March 2013, 12:59 AM   #17
HawaiiGuy is offline HawaiiGuy
Is the output transformer's primary bifilar wound?
Transformer covers:
tube sockets, tube amps items in tube audio DIY store on eBay!
Old 20th March 2013, 12:19 AM   #18
mr2racer's Avatar
You mean the secondary don't you? Yes the secondary is bifilar. I saw those on Ebay. I would need $220 worth plus shipping. I can build four and powdercoat them for less than $50
Tom, the feedback windings have same spec as original. The original circuit will be a good starting point.
Marrantz Model 9 Transformer BuyHide this!Advertise here!
Where you buy iron transformer core for DIY audio transformer tarsik Tubes / Valves 10 27th December 2011 08:15 PM
Moded marrantz 63 bull041161 Digital Source 2 28th April 2010 09:58 PM
Marrantz Cd42/52 Draw Gear bull041161 Digital Source 8 14th January 2010 05:30 PM
marrantz diy dac bull041161 Digital Source 44 2nd July 2009 07:09 AM
Where can I buy DYNAUDIO WOOFER DRIVER model MW150 aht Subwoofers 2 16th March 2005 06:33 AM
