6N2P/6Н2П low plate current increases noise?
Old 27th January 2013, 09:20 AM   #1
FLT is offline FLT
Default 6N2P/6Н2П low plate current increases noise?
Hello everybody,
I am using the 6N2P as diff-amp-phase-splitter input of my current project.
Plate current per system is 0.5mA, taken from "http://www.rutubes.com/index.php?show_aux_page=6"
(How to use 6N1P and 6N2P Russian tube).
The screen/pin 9 is grounded, but after a while the noise increases a lot.
I had no idea why, so i tried several tubes of that type - no success.
Yesterday i changed the plate current to 0.7 and 1.0mA. The noise decreased a lot.
Now my question: Has anybody else seen this problem?
regards
Frank
Old 27th January 2013, 08:58 PM   #2
Ketje is offline Ketje  Belgium
Ketje's Avatar
Probably you changed the current by making the cathode resistance smaller.
If there is noise comming from the heater it is now more shortcicuited to gnd (or supp) and has less influence.You could test this by putting a capacitor between cathode and ground.If the noise disappear it came from the heatercicuit.
Mona
Old 28th January 2013, 05:57 AM   #3
FLT is offline FLT
Thanks for your answer.
I'm not shure, the noise is hiss(like pink noise), not hum.
regards,
Frank
Old 28th January 2013, 11:56 AM   #4
roline is offline roline  United States
roline's Avatar
I prefer 12BH7, 7062, JAN6414, 12AU7, 6N6Pi, for phase splitters running at higher bias, ~5ma. 6N6Pi is a favorite in this application, but a power monger....
I also prefer to run 12AX7, 12BZ7 and 7025 tubes around ~2mA. I've found Ei ECC83 long smooth plates to be good for low noise (both hum, hiss) in a RIAA phono amp front end.
SO many tubes, SO little time!!!
Old 28th January 2013, 04:13 PM   #5
artosalo is offline artosalo  Finland
artosalo's Avatar
I have used 6N2P-EV with 0.3 mA in RIAA front end and with no hiss problem.
Actually the hiss level was higher with higher anode current.
At what signal level your stage works ?
Old 29th January 2013, 08:31 AM   #6
FLT is offline FLT
Input was 0.087Vrms, Output 1.64/1.63Vrms(at 1kHz) for testing.
More Output makes the driver clip.
regards
Old 29th January 2013, 02:11 PM   #7
artosalo's Avatar
Basically I wanted to know do you plan to use this 6N2P at the line levels or at RIAA levels.
At line levels the noise is never a problem. Usually S/N is some 100 dB at well built line stage.
Old 30th January 2013, 08:09 AM   #8
FLT is offline FLT
Line level.(Input stage of power amp)
I grounded the input and listened to the speaker.
There was certain amount of noise, decreasing with more plate current.
Disconnecting the input/LTP stage from power stopped the noise, so it
is the LTP - not the driver stage that makes the noise.
regards
Old 30th January 2013, 02:57 PM   #9
scott17 is offline scott17
Are you using a grid stopper?
It could be oscillating.
Old 31st January 2013, 09:51 AM   #10
FLT is offline FLT
Yes, i have gridstoppers.
Oscillation was my first thought, but the noise disappeared with higher plate current.
regards
Frank
6N2P/6Н2П low plate current increases noise?Hide this!Advertise here!
6CG7/6FQ7 = 6N5P (6Н5П) lordearl Tubes / Valves 9 3rd December 2011 10:21 PM
Service Life at Low Plate Current payloadde Tubes / Valves 14 5th September 2011 03:26 AM
6Н30П spice model for MicroCap ? bogdan_borko Tubes / Valves 0 5th September 2010 11:54 AM
Low noise current source jgedde Solid State 2 11th February 2008 03:26 PM
Low noise current source hugobors Solid State 5 25th January 2006 11:50 PM
Copyright ©1999-2017 diyAudio
