rogers cadet 111 or Quad 11
Old 26th January 2013, 08:50 PM   #1
stevebro is offline stevebro  United Kingdom
Exclamation rogers cadet 111 or Quad 11
Just to revive an old forum,
I purchased a cadet 111 some years ago and when I fired it up everything was fine and then put it in to (dry) storage until now. never really checked the balance control. what I've discovered is that when you turn the balance control to the left the sound is somewhat dull compared to turning the knob to the right-what a difference-its like double the sound.
So, to any rogers experts out there what could be causing this. This is only to be used for vinyl only, so I would appreciate any recommendations or opinions.
Any good places to source some right angle spade connections for the speaker terminals. The current ones (original) are a pain in the backside to connect up too.
Also thinking of upgrading to some Quad 11 mono-blocks- are they worth the extra. Again for Vinyl use only.
Any advise welcome.
Regards & thanks in advance
Garrard 401, SME 3009 S2 imp, Tannoy Gold 12
Old 27th January 2013, 12:21 AM   #2
oldschooltube is offline oldschooltube  United States
oldschooltube's Avatar
As far as the balance control goes have you used Deoxit? I had a similar problem with a kit amp that I built and stored for a long time. The control was very crackly and muddy sounding because the internal disc that the wiper rides on had oxidized. I soaked the control and worked it between it's extremes about 50 times and then used canned air to blow it out. Works fine ever since. Just an idea. I am not entirely familiar with this amp but the coupling caps might be on the way out as well.
Marty: "Why don't you just make 10 louder?"
Nigel: "...These go to 11."
Old 27th January 2013, 12:37 AM   #3
thanks for the reply and advise but I think the problem lies beyond that kind of fix. No crackly sound at all when you turn the knob, just a difference in the volume twice throld may be even thrice.
Old 27th January 2013, 01:35 AM   #4
Have you tried swapping all the right channel tubes with the left? Start simple. I just had a hard reminder of start simple with a pair of Altec 1570b amps. (See thread "red plate of doom").
Old 27th January 2013, 09:51 PM   #5
Thanks for the Info, Just tried that and there's no difference. Swapped around the 4 at the back-no change, then the 3 at the front again no change.
Just to make sure it was nothing to do with the cartridge or needle I have a an old pioneer transistor amp from a middi system that has a phone Input. Hooked that up and balance control worked fine.
Any more tips would be welcome bearing in mind I don't have a scoobie about electronics
Old 27th January 2013, 10:08 PM   #6
enzoastro is offline enzoastro  United Kingdom
I think the Quads are regarded as quite a lot higher quality. mine measure great as well as sounding good.
0.1% @ 15W and 5% @22W with 5881 and original ef86.
did i mention they're for sale, so I'm biased!
enzo
Old 27th January 2013, 10:29 PM   #7
what are the dimensions, any pics or are they on that auction site?
Old 27th January 2013, 10:43 PM   #8
12.5" x 6.5" x 5"
They are not on #bay yet as i was looking for the original manual which i have somewhere...
I can get you some photos if you'd like?
They have Audyne polypropylene power supply and coupling caps fitted and normal rca inputs & 4mm banana speaker sockets so can slide into a conventional hifi system. love them.
Old 27th January 2013, 10:49 PM   #9
some pics would be nice. Is the 6.5" height or width
Old 28th January 2013, 02:43 PM   #10
Hight
Some pics
cons are one of the badges is missing. 1966 vintage I'm the second owner!
Audio Photos by enzoastro | Photobucket
rogers cadet 111 or Quad 11Hide this!Advertise here!
Rogers Cadet 3 Problem zedrider Tubes / Valves 26 7th January 2018 09:55 AM
Help with rogers cadet 3 integrated mbam55 Tubes / Valves 3 14th December 2012 03:02 AM
Rogers Cadet III integrated harlequin Tubes / Valves 3 26th March 2010 07:33 PM
Rogers cadet 3 soulie12000 Tubes / Valves 8 29th January 2010 08:13 AM
Rogers Cadet III Schematics needlesview Tubes / Valves 23 14th September 2007 08:50 AM
