rogers cadet 111 or Quad 11 - Page 2 - diyAudio
Old 29th January 2013, 12:45 PM   #11
Both amps are great though the Quad has twice the power.
The Cadet does NOT ever require coupling caps changing as they are Mullard mustards and 100% reliable. The Quad however is a different story and Does reqire the coupling caps changing as they are horrid leaky paper types.
Old 29th January 2013, 08:29 PM   #12
Thanks for the Info, any advise on the balance control?
Old 30th January 2013, 12:16 PM   #13
Can't immediately think of anything obvious, havn't got the circuit in front of me. Where are you 9Approximately).
Old 30th January 2013, 01:52 PM   #14
Dundee
Old 30th January 2013, 06:39 PM   #15
Ok so no chance of just dropping by for a quick look then.
Old 30th January 2013, 07:17 PM   #16
Depends where you are, I take it your way down south of the border. I tried to attach the circuit diagram but it was to large a file. I could PM you if that would help.I got them from HiFi engine.
Thanks for your Interest
Old 30th January 2013, 07:28 PM   #17
Default Balance control
Don't know if this will work but I've copied the link below
Rogers Cadet III Tube Ampifier | HiFi Engine
Old 30th January 2013, 07:36 PM   #18
This is a better link. the one above only shows a photo.
http://www.bassboy.com.au/getreel/si...cadet3/amp.htm
Old 31st January 2013, 07:37 AM   #19
Yes way south in Surrey.
Had a look at the circuit diagram and it could be a problem with the caps marked C3, one may be very low?
Help with rogers cadet 3 integrated mbam55 Tubes / Valves 3 14th December 2012 03:02 AM
Rogers Cadet 3 Problem zedrider Tubes / Valves 25 26th May 2010 05:33 PM
Rogers Cadet III integrated harlequin Tubes / Valves 3 26th March 2010 07:33 PM
Rogers cadet 3 soulie12000 Tubes / Valves 8 29th January 2010 08:13 AM
Rogers Cadet III Schematics needlesview Tubes / Valves 23 14th September 2007 08:50 AM
Copyright 1999-2017 diyAudio
