Old 26th January 2013, 07:40 PM   #1
Default 12ax7(ecc83) and 6n2p 12ax7...........differents??
hello guys...just ask something the 12ax7 is different with 6n2p 12ax7??????????????????? help....bought or not
Old 26th January 2013, 08:12 PM   #2
DF96 is offline DF96  England
12AX7 and ECC83 are virtually the same, although in theory a real ECC83 will always have a low noise spiral-wound heater; a 12AX7 might not, although many actually do.
6n2p is a similar Russian valve, but with different heater arrangements. To use it in a 12AX7/ECC83 circuit you need to rewire the heaters.
Old 26th January 2013, 08:14 PM   #3
Harleyjon's Avatar
Send a message via Skype™ to Harleyjon
ECC83/12AX7
1 = A 2 = G 3 = K 4 = Htr 6.3V 5 = Htr 6.3V 6 = A 7 = G 8 = K 9 = Htr Centre tap 0V
6N2P
1 = A 2 = G 3 = K 4 = Htr 5 = Htr 6 = A 7 = G 8 = K 9 = Scrn
The Hfe and noise figures are similar to ECC803, better than ECC83
The heater of 12.6 vbolts across 4 & 5 with a centre tap at pin 9 is the difference. Rewiring of the valve base will be required.
Preamp with single 12ax7 Ecc83 for stereo? Rodeodave Tubes / Valves 16 20th April 2012 06:11 AM
Telefunken ECC83 / 12AX7 Used (Old Stock) sorenj07 Swap Meet 2 6th January 2009 03:02 PM
ECC83/12AX7 Tube test query waam68 Tubes / Valves 8 8th November 2007 07:52 PM
Grant RIAA phono with 12AX7/ECC83 soulmerchant Tubes / Valves 12 30th October 2006 12:36 PM
Fun circuit with a 12ax7 (ecc83) ebijma Tubes / Valves 7 20th April 2005 07:33 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
