Old 26th January 2013, 07:18 PM   #1
Default Heater supply
A schematic I plan to use shows 12AU7 input valves heated by 6.3 volts AC that floats on (approximately) 90v DC.
If I was to use 12.6 volts DC for the heaters should it still float on the 90 volt DC as above or simply be connected straight to the heaters.
The 12AU7 cathode voltage is shown as 4.4 volts so heater/cathode difference is not large.
Old 26th January 2013, 07:22 PM   #2
Frank Berry's Avatar
The same d.c. voltage will apply.
Frank
Old 26th January 2013, 07:32 PM   #3
Ketje is offline Ketje  Belgium
Probably you mean 'straight to the ground'
On first sight with the cathode only 4.4V ,yes.But perhaps there is a reason for the 90V.The 4.4V could be only the steady-state but with a large voltage swing superimposed.Without a schematic,hard to say.
Mona
Old 26th January 2013, 08:15 PM   #4
DF96 is offline DF96  England
90V seems a high voltage to elevate a heater supply for a valve with its cathode at only 4.4V. Does the supply also feed another valve with a higher cathode voltage, such as a cathode follower? In most cases there is no reason to use a DC supply for heaters, as AC is perfectly good if wired correctly.
Old 26th January 2013, 08:58 PM   #5
This heater circuit supplies two 12AU7 valves, one per channel.
I probably should keep the AC supply, it's simpler than making a DC supply.
I had presumed the DC would produce less hum.
Old 27th January 2013, 01:22 AM   #6
Triodethom's Avatar
Historically 45 to 50 volts for 12a..7 is good to reduce noise . 90 volts are a bit high but still below the max.
Old 27th January 2013, 03:06 AM   #7
roline is offline roline  United States
roline's Avatar
I'm floating the 12VDC heater supply at 70 volts for a SRPP based RIAA amp... Quiet as a church mouse....
SO many tubes, SO little time!!!
Old 27th January 2013, 04:34 PM   #8
Yes, but an SRPP has one valve sitting at a high voltage so the heater supply may have to sit somewhere between the two cathodes. Normally, 40V is the recommended DC offset for a heater supply. Most decent NOS valves with good heater-cathode insulation are happy with a grounded heater supply.
Heater supply Navyblue Tubes / Valves 27 16th April 2012 05:53 PM
Is this OK for a heater supply? blacklight Tubes / Valves 9 12th December 2006 05:58 PM
Is this heater supply OK? Nuuk Tubes / Valves 39 18th August 2006 11:20 PM
help with heater supply jarthel Tubes / Valves 5 24th July 2003 01:12 PM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 01:30 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
