| diyAudio Sponsor | ||
i have a 24VCT (7A), 14VCT (3A) transformer. if possible i'd like to use this in making a tube headphone amplifier as i have it and a new tranformer would be at least $8 for shipping alone...
so i was thinking of voltage doublers, quadruplers, triplers, ect... but even with a voltage quadrupler, i still can't get much over 100Vdc, and i will have more ripple. so i wanted to know what tubes work well with mid voltage. not low voltage like 12V car tubes, though i could use them if you guys reccomend them. realize that i have little money, so please reccomend affordable tubes that aren't $100+ each. try for $10 or less each.
if only it could be used for good, not evil... |
#2 |
100v can work fine for a headphone amp..
6DJ8 or 6N1P would probably work OK for this.. 1/2 as gain and 1/2 as a CF |
#3 |
You can multiply the voltage from the transformer secondary up as far as you dare!
http://www.google.com.au/search?q=co...=Google+Search |
| Cathode stripping in low voltage tubes | engels | Tubes / Valves | 1 | 26th March 2008 05:05 PM |
| A use for those old voltage regulator tubes | zigzagflux | Car Audio | 0 | 22nd July 2007 10:01 PM |
| Voltage Regulator Tubes | dsavitsk | Tubes / Valves | 5 | 27th March 2007 11:01 PM |
| Low voltage tubes | cozza | Tubes / Valves | 4 | 27th March 2005 08:31 AM |
| low voltage tubes (6GM8 and 12DL8) | needtubes | Tubes / Valves | 28 | 17th July 2003 10:09 PM |
| Page generated in 0.06575 seconds (71.85% PHP - 28.15% MySQL) with 10 queries |
