How biasing mA in tubes
Old 26th January 2013, 06:36 PM   #21
DF96 is offline DF96  England
LTspice won't design anything for you. It may tell you whether your design will work. Choosing the current through a valve is part of design. Obtaining that current is another part of design.
In general, it is unwise to rely too much on statements like "the ECC81 should have 5mA current". Instead, study the datasheet and find out why people recommend a particular working point. Bear in mind that some of them may be wrong, or just repeating what someone else told them.
Old 26th January 2013, 08:49 PM   #22
merlin el mago is offline merlin el mago
merlin el mago's Avatar
How can understand the datasheets to study? wich parameters I have to look for? how can be sure I'm not wrong like the others?
Old 26th January 2013, 09:33 PM   #23
Let's see if I understand something of the ECC81 datasheet applicated to posted mu-follower schematic:
Schematic uses upper anode 280V the max anode dissipation is 2.5W
Looking at curves shows 9mA for upper anode
Grid voltage aprox -2,66V
Schematic uses lower anode 85V the max anode dissipatios is 2.5W
Looking at curves shows aprox 27mA for lower anode
Grid voltage aprox. +3V
Are my calculations OK?
Old 27th January 2013, 12:17 PM   #24
Ketje is offline Ketje  Belgium
Ketje's Avatar
If you try to turn up the current to 5mA the voltagedrop at 33k resistor is 165V.Starting with 280V that leaves 280-165=115V for two tubes.But with 115/2=57.5V on a ECC81 -Vg is almost zero to reach 5mA.
Best stick with 3mA.Data ECC81 ;Va=85V Ia=3mA at -Vg=1 so Rk=330ohm ,not 470 nor 560.
Mona
Old 27th January 2013, 02:19 PM   #25
Mona
If I understood correctly I have to change 560R & 470R for 330R in both places?
If I do this how many mA will be biased in both triodes?
Felipe
Old 27th January 2013, 03:53 PM   #26
Ketje's Avatar
Felipe
Mona
Old 27th January 2013, 04:00 PM   #27
Sorry Mona, wich resistor have I to replace for 330R:
-470R or 560R?
-or both?
Old 27th January 2013, 04:01 PM   #28
Actually I'm using two red leds instead 470R // 22uF
Old 27th January 2013, 04:30 PM   #29
Read some books. RDH4 is available free on the internet. Morgan-Jones is available from bookshops, both real and virtual. Also try Valve Wizard site (Merlin Blencowe).
Old 27th January 2013, 04:37 PM   #30
Chris Hornbeck is offline Chris Hornbeck  United States
Chris Hornbeck's Avatar
The part you want to learn about is called "load lines". Valves' characteristic curves are drawn with anode current on the Y axis and anode voltage on the X axis, for various grid 1 voltages.
With a little familiarity you'll soon see what is a good and what is a bad load line for your circuit and use. Well worth a small learning curve for a deeper knowledge.
All good fortune,
Chris
How biasing mA in tubesHide this!Advertise here!
For sale: 2 x Fivre 2A3 Single Plate, 60 mA + 44 mA emission on Funke W20 2A3 Maniac Swap Meet 3 1st October 2011 12:18 PM
CL ad for tubes in MA. FYI only. Not connected dbster Tubes / Valves 0 16th April 2011 07:07 PM
Crown MA-12000i / MA-5000i / MA-9000i jack2040 Solid State 4 8th March 2011 01:21 PM
Tubes measured in microhms = mA..? max29 Tubes / Valves 2 11th December 2007 03:04 PM
Marantz MA 500 or MA 700 schematic krishu Solid State 0 15th March 2004 01:59 PM
