PSU id and help (psu designer ii) PSU id and help (psu designer ii) - Page 2 - diyAudio
Old 27th January 2013, 05:11 PM   #11
DF96 is offline DF96  England
That may be a reasonable estimate. You can calculate quiescent current by using Ohm's Law on the cathode resistors. A typical push-pull Class A output will increase its current draw by 10-20% at full output, but that will only be on music peaks so can almost be ignored. Class B will increase more, of course.
A design should say what current it draws. The designer must know, because it is part of the design process.
Old 27th January 2013, 05:21 PM   #12
kstagger is offline kstagger  United States
kstagger's Avatar
with PSUD2, instead of an end resistor, you can use a constant current load. It's much handier than a final resistor - especially if you really do know what the "average" mA will be. Obviously easier with a Class A circuit.
Old 27th January 2013, 06:28 PM   #13
surfstu is offline surfstu  United Kingdom
Great guys thanks...
So for the circuit posted below I can assume that V across the cathode of final stage is 10.5 V and the cathode R is 390ohms...
Therefore I = 10.5 / 390 = 0.0269 or 27mA
This is the idle current which would be the same as the quiessent current seeing as this amp operates mainly in class A (is this correct?)
and.... I,m still trying to figure out how the first stage only draws around 1mA and has a constant current source to determine this...
my limited background in physics always taught me that the current was the same for the entire circuit?
Old 28th January 2013, 07:18 PM   #14
Default Source resistance calculated 1
Ok, thanks to all here - I'm making headway!
primary resistance = 9ohms
secondary resistance = 63ohms (CT to Sec)
Source resistance = (primary resistance / (Vpri/Vsec)2) + Secondary resistance
Vpri = 230
Vsec = 270
(Vpri/Vsec)2 = 0.726
therefore Source resistance = 75.3ohms
PSU id and help (psu designer ii)Hide this!Advertise here!
PSU Designer II question ccschua Tubes / Valves 2 20th June 2009 03:40 PM
Is PSU Designer II correct? zxx123 Tubes / Valves 7 20th January 2008 05:21 PM
Duncan PSU Designer II MattM Pass Labs 2 2nd February 2005 08:24 AM
Need some help with PSU Designer II Bricolo Parts 12 14th November 2002 06:42 PM
Copyright ©1999-2017 diyAudio
