The all DHT SET Headphone Amp
Old 3rd April 2018, 12:51 PM   #811
Abszero is offline Abszero  United States
Abszero's Avatar
Originally Posted by gug42 View Post
@Abszero : Thank you for thoses reports ! Wich headphones did you have use ?
For 32 to 70 Ohms headphones, between LL1664 (ratio 19) and LL2765 (ratio 12) wich one could suit the best
Thank you evry one
I've used a 250 ohms Beyerdynamics 880pro, which sounded nice on both 12:1 and 6:1 of the LL2765.
In my opinion, you should use the LL2765 which is a dedicated headphone output tranny. You'll have more power output compared to the 1664 and you'll need it when using the HE-500. Also for the same power output you'll need less gain using the LL2765.
I've seen on 6moons that the recommendation for the HE-500 is a 1 W output amplifier. So a 300B or 50 would be more appropriate for your headphones.
4p1l can also be a choice but expect a bit of microphonic sensitivity. Still think the 45 is the best compromise. And there are many options of new production, expensive though.
Radu
The all DHT SET Headphone AmpHide this!Advertise here!
High end Ortho Amp on a basic Russian Tube DHT SET DIY design regal Headphone Systems 2 7th December 2012 11:46 AM
300b all-DHT SET andyjevans Tubes / Valves 16 24th August 2012 08:06 PM
Help on designing full DHT SET power amplifier milen007 Tubes / Valves 56 11th August 2011 09:38 PM
Class A, DHT driven, headphone amp iko Headphone Systems 100 26th March 2011 02:54 PM
