The all DHT SET Headphone Amp The all DHT SET Headphone Amp - Page 3 - diyAudio
Old 26th January 2013, 12:56 PM   #21
iko is offline iko  Canada
iko's Avatar
Originally Posted by regal View Post
I got out my quad of 4P1L's, boy they are odd looking tubes. Trying to find a western equivalent, spec wise I think they are sort of a cousin of the 306A/307A ?
Look closer, they aren't very similar to the 307a. The 307a gives better results in the output stage, AFAIC. But then, the 307a beats the 300b, so...
Old 26th January 2013, 02:19 PM   #22
iko's Avatar
BTW, I have ONE piece of 306A. Only one.
But I'm hopeful that 4P1L will make a great tube for the headphone amp.
Old 26th January 2013, 06:49 PM   #23
Wavebourn is offline Wavebourn  United States
Wavebourn's Avatar
No Western equivalents. They were designed by Telefunken for German military. After WW-II repackaged for Soviet military purposes. The majority of special Telefunken military tubes was repackaged in loctal envelopes, except LS-50 that was too big for that.
Soviet 4П1Л = Telefunken 2,4LS1 in Loctal envelope.
The Devil is not so terrible as his math model is!
Old 27th January 2013, 02:08 PM   #24
regal is offline regal  United States
I received a couple quotes for single-feed 5k:40 output transformers.
For a pair made by the brits its a bit over $400, with guarantee to design for lowest secondary dcr/inductance M6.
For pair made in sin city its about half that price but not guarantee on high dcr, probably M19.
Then there are china elcheapos called BEZ's that are 4k: 32-64-100-200 for only $100 shipped.
No response from the parafeed experts Magnequest, so rule that one out. Cinemag has some interesting mic ouput transformers that could be good for parafeed, but probably too small for orthos's power.
So its either britain, LV-USA, or China. Have no idea which direction to take.
Old 27th January 2013, 03:28 PM   #25
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Have you asked Lundhal and Bartolucci?
Brits are Sowter, right?
Old 27th January 2013, 04:54 PM   #26
yes Brits are sowter. I don't see anything in th lundhal catalog that would work and understand that they have a long lead time for custom stuff.
Old 27th January 2013, 04:56 PM   #27
If you want can I ask Giuseppe Bartolucci a quote for single-feed 5k:40 output transformers?
Old 27th January 2013, 04:58 PM   #28
danFrank is offline danFrank  United States
Hi everyone...
A bit off-topic but for those of you using the SSHV regulators, what op-amp are you using in the regulator? I understand that some of the high end op-amps that can be used cause oscillation in the SSHV circuit.
One more thing... Wouldnt permalloy cored transformers be better for use as a headphone amp as they are much more sensitive magnetically? Like the UTC LS or HA series of transformers?
Thanks for your time... Daniel
Old 27th January 2013, 05:12 PM   #29
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
Originally Posted by danFrank View Post
Hi everyone...
There are no opamps in the SSHV2. Better ask more questions to the appropriate thread, you will get more response there.
"Without deviations from the norm, progress is not possible" - Frank Zappa
Old 27th January 2013, 05:13 PM   #30
Stixx is offline Stixx  Germany
Stixx's Avatar
There is no op-amp in SSHV regulators... the beauty of them is the simplicity (it is even part of the name ) and the sonic character of course.
vgeorge beat me to it
The all DHT SET Headphone AmpHide this!Advertise here!
High end Ortho Amp on a basic Russian Tube DHT SET DIY design regal Headphone Systems 2 7th December 2012 11:46 AM
300b all-DHT SET andyjevans Tubes / Valves 16 24th August 2012 08:06 PM
Help on designing full DHT SET power amplifier milen007 Tubes / Valves 56 11th August 2011 09:38 PM
Class A, DHT driven, headphone amp iko Headphone Systems 100 26th March 2011 02:54 PM
Copyright ©1999-2017 diyAudio
